6x14 Window Placement Question
Re: 6x14 Window Placement Question
Postby MrBo » Sat Jan 06, 2018 11:10 pm
Iconfabul8 wrote:I figured after we zeroed in on just what you wanted, I could then get you a printable copy or whatever format you want, because I have to shrink these a lot to display on the forum.
very much appreciated. Tried to blow up but cuts off. Can not tell if the 18x42 cuts off or is the full window. Hard for me to see the details. I will try it on a larger screen and see if that works.
Mr Bo
6x14 Build Log - Rolling Thunder - Cabin on Wheels - http://www.tnttt.com/viewtopic.php?f=42&t=69971
MrBo
Postby MrBo » Sat Jan 06, 2018 11:35 pm
They look good, just did not want to keep taking up your time on this.
The main placement I am concerned about is the side with the door.
Maybe if you did them with one shot at a time instead of together side by side it would be easier for me to see and figure out. Just a thought. When I use control + it cuts the door image off.
Thanks!
Mr Bo
MrBo
Postby Iconfabul8 » Sat Jan 06, 2018 11:43 pm
Here is one you can see! I dropped the window to 33" and that gives you 12' on top. Threw a bed in for perspective, it is 12" from the wall. So figure where you like all the windows and lets get a final whipped out. No hurry tho, take your time and make sure it is what you want. I don't mind making any changes you want.
Iconfabul8
Images: 14
Postby McDave » Sat Jan 06, 2018 11:46 pm
hankaye wrote:MrBo, Howdy;
Use Ctrl and tap on the + tab at the same time poof, gets bigger.
Likewise Ctrl and - and it reduces ...
hank
Wish I had known that about 3 years ago. Better late than never.
Thanks Hank!
McDave
McDave
Images: 412
Postby MrBo » Sun Jan 07, 2018 12:14 am
Iconfabul8 wrote:Here is one you can see! I dropped the window to 33" and that gives you 12' on top. Threw a bed in for perspective, it is 12" from the wall. So figure where you like all the windows and lets get a final whipped out. No hurry tho, take your time and make sure it is what you want. I don't mind making any changes you want.
I can see it NOW! :lol: Thank you!
The one window under consideration was 18x42, I was wrong on the size. It will not work in this set up. I am able to drag into photo shop and play with a little. This really helps a lot. let me put a little thought into this on what sizes will work best now that I can see. Will get back tomorrow. Will have to move things a little.
Again thank you.
Mr Bo
MrBo
Postby hankaye » Sun Jan 07, 2018 11:05 am
McDave, Howdy;
hank
Thanks Hank!
McDave
I ain't any kind of computer whiz, a 7 year old showed me that... :lol:
hank
hankaye
Postby MrBo » Sun Jan 07, 2018 3:00 pm
So here is what I am thinking.
Passenger side the 30x30 moved over 16" from door and going with the 15x24 horizontal moved over (about 4' from the back.) height about middle of the 30x30.
On the divers side a 18x42 horizontal window about 4' from the back going towards the front and about 49" from the floor.
Hope that makes sense. Thought or comments please feel free.
Thanks again and no hurry.
Mr Bo
MrBo
Postby Iconfabul8 » Sun Jan 07, 2018 11:00 pm
Ok, looks like we might be getting close.
152526
Iconfabul8
Images: 14
Postby MrBo » Sun Jan 07, 2018 11:06 pm
Looks great! The only thing I would change is maybe make the the 18x48 12 inch from the top like the 30x30.
Mr Bo
MrBo
Postby Iconfabul8 » Sun Jan 07, 2018 11:10 pm
Is it an 18 x 48 or 18 x 42 ?
Iconfabul8
Images: 14
Postby MrBo » Sun Jan 07, 2018 11:11 pm
Sorry bout that 18x42
Mr Bo
MrBo
Postby Iconfabul8 » Sun Jan 07, 2018 11:31 pm
152527
Iconfabul8
Images: 14
Postby MrBo » Sun Jan 07, 2018 11:32 pm
Looks Great!
:applause:
Mr Bo
MrBo
Postby Iconfabul8 » Sun Jan 07, 2018 11:36 pm
Let me know if you need it in a pdf or other format. The last two were actually loaded into the gallery. It should print on an 8 1/2 x 11.
Iconfabul8
Images: 14
Postby MrBo » Mon Jan 08, 2018 12:02 am
Iconfabul8 wrote:Let me know if you need it in a pdf or other format. The last two were actually loaded into the gallery. It should print on an 8 1/2 x 11.
Thank you!
Sent from my VS995 using Tapatalk
Mr Bo
MrBo
