Recessed LED 110 Ceiling Lights
Postby phoenixbound » Sun Feb 11, 2018 9:30 am
Looking for product suggestions. I have two externally mounted fluorescent lights in CTC with the standard 6' height. I am only 5'9" so I can walk under them without whacking my head (good to be short??). Still, I would like to replace them with some recessed LED's because I need the clearance to mount my bed support (more on this later). I have seen several CTC folks mount recessed LEDs and am asking if you could share product id, part number or whatever can point me to the right light. I will be using the existing wiring to power them and I am guessing about a little more than an inch of space to work with. Thanks.
Phoenixbound
phoenixbound
Re: Recessed LED 110 Ceiling Lights
Postby tony.latham » Sun Feb 11, 2018 11:23 am
phoenixbound wrote:Looking for product suggestions. I have two externally mounted fluorescent lights in CTC with the standard 6' height. I am only 5'9" so I can walk under them without whacking my head (good to be short??). Still, I would like to replace them with some recessed LED's because I need the clearance to mount my bed support (more on this later). I have seen several CTC folks mount recessed LEDs and am asking if you could share product id, part number or whatever can point me to the right light. I will be using the existing wiring to power them and I am guessing about a little more than an inch of space to work with. Thanks.
Phoenixbound
You might Google: "Led Disc Light". They may work for you.
T
Postby MrBo » Sun Feb 11, 2018 12:04 pm
Here is a product I am ordering for my conversion. Have not received them yet.
12v-LEDlight Marine White Recessed LED Ceiling Lights - Easy to Install (screw free) Cabinet Counter Lamp Campervan Trailer 5th Wheel RV Truck Car Bus, 3w, Bright Natural White, Pack of 6 with Bonus $36.99 The reviews are good. 3 wat
https://www.amazon.com/12v-LEDlight-Mar ... op?ie=UTF8
Here are some easy switches I am looking to order as well... if that helps. The switches you just drill a hole to size and they pop in.
Yueton 12pcs Car Truck Rocker Round Toggle LED Switch On-Off Control, Blue, Green, Yellow, Red $6.99 https://www.amazon.com/gp/product/B011U ... SCVJ&psc=1
Hope this helps. Also if you do the link on the lights it should suggest other similar products. Opps just noticed after posting 110 not 12v. Do a search and change 12v to 110 and see what comes up.
Update: here is a 110 4 PACK - 13W 5/6inch Dimmable LED Retrofit Recessed Lighting Fixture (=75W) 4000K Cool White Energy Star, UL, LED Ceiling Light - 965 Lumens Recessed LED Downlight $29.99 https://www.amazon.com/dp/B01N41GZD1/re ... B01I24XG7Y if you click on the link look at the bottom for a ton of sugested lights like this.
Mr Bo
6x14 Build Log - Rolling Thunder - Cabin on Wheels - http://www.tnttt.com/viewtopic.php?f=42&t=69971
MrBo
Postby McDave » Mon Feb 12, 2018 6:12 pm
http://faroutride.com/led/
Stole that link from Pigtrail
McDave
McDave
Images: 313
Postby flboy » Tue Feb 13, 2018 1:18 pm
This is what I used. They work great and I like them. The good thing about them is that they do not need much area/depth for recess. I used them in my kitchen and dinette area, but they would work well anywhere.
These are 12vdc, but if you do not have batteries or etc... you could buy a cheap 12vdc power supply that runs off 110 VAC and use that to run lights. You could pick up a relatively cheap one that will do more lights than you can run for about $20.00. You will be all wired in that case if you ever get a battery and converter for upgrade later. All my lighting is 12vdc, but basically runs from 110vac when plugged in via the converter which also charges the batteries.
Just something to think about. :-) Obviously, probably not what you need if you are hard set on using the same wiring.
From Amazon:
Dream Lighting LED 2.76inch Recessed Ceiling Down Light for RV Trailer Motorhome Coach Boat Cabin Kitchen Cabinet Indoor Lighting-Dimmable Cool White, Silver, Pack of 2
https://www.amazon.com/dp/B00ODSASAW/re ... GAbTGDXJGX
A 12vdc PS to run them off 110VAC
SUPERNIGHT DC 12V 30A 360W Universal Regulated Switching Power Supply .
https://www.amazon.com/dp/B01LATMSGS/re ... GAb80DWJ5D
Recessed LED Lights In use under kitchen cabinet in my CTC
Don (Flboy)
Current Build CTC:
viewtopic.php?f=42&t=65498
Old CTC Build (sold)
viewtopic.php?f=42&t=50647
YouTube Videos of Finished Trailer:
https://www.youtube.com/watch?v=FASF-x9ofMY - Interior
https://www.youtube.com/watch?v=wb-pvBbyyBs - Exterior
flboy
Images: 375
Postby MrBo » Fri Mar 16, 2018 9:53 am
flboy wrote:This is what I used. They work great and I like them. The good thing about them is that they do not need much area/depth for recess. I used them in my kitchen and dinette area, but they would work well anywhere.
Looks GREAT!
Mr Bo
MrBo
