6x14 Cargo Conversion Build Log - Rolling Thunder
Re: 6x14 Cargo Conversion Build Log - Rolling Thunder
Postby MrBo » Wed Apr 11, 2018 1:07 pm
MrBo wrote:
Padilen wrote:You can get a copper line and adapter, then go with hose. They even make quick connects. I think I gave my 3 burner that had a hose and quick connect to the guy that refrubs old travel trailers. I look and see if I have it and will post a pic if I do.
Thanks! Picture would be a big help.
Do you know if they make some sort of gasket I can use to fill in hole through botton for hose. I will have to drill a one inch hole for the heater buddy hose as well as the stove hose.
Mr Bo
6x14 Build Log - Rolling Thunder - Cabin on Wheels - http://www.tnttt.com/viewtopic.php?f=42&t=69971
MrBo
Postby Padilen » Wed Apr 11, 2018 1:51 pm
You mean in floor or wall of CT?
Padilen
Postby MrBo » Wed Apr 11, 2018 1:53 pm
Floor
Mr Bo
MrBo
Postby Padilen » Wed Apr 11, 2018 7:33 pm
Floor
Ok I got busy, but I still have the 3burner. I'll get at it tomorrow.
For the floor I'd do one hole, and a deck plate or some sort of port with door/lid. If it's in an area that doesn't need to be flush, I'd use a wire inlet. I think I even bought one to do mine, just haven't done it. Yeah I'm slow.
Padilen
Postby MrBo » Thu Apr 12, 2018 8:34 am
Floor
Thanks. Will look for that. The hole will be on the floor in the point of the v nose.
Sent from my VS995 using Tapatalk
Mr Bo
MrBo
Postby Padilen » Thu Apr 12, 2018 12:16 pm
Here is the quick connects. And hose ends.ImageImage
Padilen
Postby Padilen » Thu Apr 12, 2018 12:19 pm
Here was my idea for lines to be in.
Screw was to hold it open for pic
Padilen
Postby MrBo » Thu Apr 12, 2018 12:52 pm
Padilen wrote:Here was my idea for lines to be in.
Perfect! Thanks! I will look for that. I am not going to do a quick connect for heater buddy and just try and use the hose I have to save money as I am starting to get tapped out. I found a spot that works perfect where I can mount plus also pull out to move around if needed. The hose can be hidden in a bottom shelf.
Just need to find right fittings and hose for the stove and I can get er done!
Thanks again!
:applause:
Mr Bo
MrBo
Postby MrBo » Sat Apr 14, 2018 3:51 pm
Thanks again!
:applause:
Do you know what this thing is called? Can not find anything like it. Still looking for fittings from stove to hose. May have to go to ace....
Thanks again!
Mr Bo
MrBo
Postby hankaye » Sat Apr 14, 2018 4:21 pm
MrBo, Howdy;
You'd be better served by going to one of your local Propane dealers. Take both
ends and the pieces you are attempting to join into a working unit to them and
allow them to set you up. These are supposed to be the "Pros" let do their 'thing'.
The fittings they have available are not normally available to ACE and other corner
hardware stores.
hank
hankaye
Postby MrBo » Sat Apr 14, 2018 4:33 pm
hankaye wrote:MrBo, Howdy;
hardware stores.
hank
Thanks Hank
Mr Bo
MrBo
Postby Padilen » Sat Apr 14, 2018 5:12 pm
It can be called many things.
Look for RV power cord access port, hatch, or power cord door.
For fittings my local hardware would have more selection than a propane dealer- oh wait! They got propane too.
Padilen
Postby MrBo » Sat Apr 14, 2018 5:15 pm
Padilen wrote:It can be called many things.
If I can even find A propane store.. Most have gone out ...
Thanks! That worked for searching. :D
Just in case anyone else might be looking.
Valterra Electrical Cable Hatch for RVs - 5" Diameter - White
https://www.etrailer.com/RV-Wiring/Valterra/A10-2130VP.html?feed=npn&gclid=Cj0KCQjwzcbWBRDmARIsAM6uChXqAQkqm4hToNEHZcdNTWA9EMaBYvwNuCT-WBuYLkP_Pded4kxWZ54aAnLYEALw_wcB
DELUXE CABLE HATCH ROUND PW
https://www.walmart.com/ip/DELUXE-CABLE-HATCH-ROUND-PW/194476529?wmlspartner=wlpa&selectedSellerId=15003&adid=22222222227049412413&wmlspartner=wmtlabs&wl0=&wl1=g&wl2=c&wl3=146709091429&wl4=pla-260679217175&wl5=9028882&wl6=&wl7=&wl8=&wl9=pla&wl10=118770393&wl11=online&wl12=194476529&wl13=&veh=sem
Mr Bo
MrBo
Postby McDave » Sat Apr 14, 2018 6:44 pm
That sounded like Hank Hill talking 'bout propane and propane accessories. Strickland Propane and Thatherton Fuel are only still operating in Texas I believe.
McDave
McDave
Images: 412
Postby MrBo » Mon Apr 16, 2018 8:10 am
Update. got all the side shelves faced with pallet wood.
Love working with it and the rustic feel.
Here is a video vBlog
URL https://youtu.be/O4xhtvczUcs
Video
Also here is my easy sink Set up
URL https://youtu.be/aq9egjnuY-k
Video
Mr Bo
MrBo
