John61CT wrote:I don't see how they could be used as is, must be lengthened and raised.
Or go back to smaller tires.
Just to be clear, they're just set on the tire for the pictures, I had no intentions of running them mounted in that proximity to the tires.
The length doesn't seem to be my biggest problem, the sheer distance between front and rear is. If I raise them to the point they clear the tires adequately, they're essentially not purposeful fenders anymore (at-least not for rear exiting mud/rocks).
Smaller tires aren't ideal, since these match my tow rig and are paid for, but yes always an option.
What about trimming a few inches off the bottom of the fenders and maybe, just maybe, flaring the rear edge out some to gain clearance for a up-and-rearward swinging tire?
Either way, I appreciate the thoughts...I can usual take a day or two and come up with a fix for these problems, but this one I'm just mentally stalled on. I know there should be a way to use these, with my current setup, to achieve a cohesive design with the rest of the trailer...but it eludes me.
Jake
