Insulation expense
Insulation expense
Postby mlowry7 » Thu Mar 22, 2018 9:01 pm
Appreciate all the great information here! I’m planning either a 7x14 or 7x16 build. Just curious what your total cost for insulation was.
mlowry7
Re: Insulation expense
Postby Iconfabul8 » Fri Mar 23, 2018 2:45 am
Figuring the number of sheets by the square footage should get you pretty close.
Side walls... 14'x6'x2=168
End walls.... 7'x6'x2=84 V front will have a little more.
Roof.......... 14'x7'=98
Total sqf .......... 350 Subtract for doors and windows if you want. But you will have waste also.
Divide by 32 (sqf/sheet)...350/32=10.93
Multiply by cost of sheet...11 x 19.00= $209.00
Add a couple cans of spray foam and maybe some foil tape.
https://www.homedepot.com/p/Owens-Corni ... /207179253
Iconfabul8
Images: 14
