Water pump recommendations.
Postby firemansd19 » Tue Apr 03, 2018 8:36 pm
I’m in need of some tried and true help on the right water pump for me. I need a water pump that is reasonable to feed a sink and also to supply enough pressure/volume for a water hose. I want to be able to spray loose sand and debris off of my scuba gear before packing it back up.
firemansd19
Re: Water pump recommendations.
Postby firemansd19 » Tue Apr 03, 2018 8:39 pm
firemansd19 wrote:I’m need some tried and true help on the right water pump for me. I need a water pump that is reasonable to feed a sink and also to supply enough for a water hose. I want to be able to spray loose sand and debris off of my scuba gear before packing it back up.
Seaflo 12V 100PSI Self-priming Diaphragm Pump https://www.amazon.com/dp/B0166UBJX4/re ... XAbNBFV9ES
This is what I currently have. It does great if I was using it just for a sink. My biggest requirement is for a short (25’) water hose.
firemansd19
Postby hankaye » Tue Apr 03, 2018 9:18 pm
firemansd19, Howdy;
Just did a quick google for RV pumps and found this one,
http://www.rvpartscountry.com/Shurflo-R ... 3-GPM.html
Hope this might fill your bill ...
hank
hankaye
Postby John61CT » Tue Apr 03, 2018 9:28 pm
Check out Whale as well as Shurflo
John61CT
Postby KTM_Guy » Tue Apr 03, 2018 11:56 pm
I would go with a high GPM over high PSI to just spray sand and stuff off. You didn't say what your fresh water source is? If a storage tank how big? 15 gallon tank with a 3 GPM pump = 5 minutes till empty.
Hard to go wrong with a Sureflo.
Todd
KTM_Guy
Images: 193
Postby kramergwt » Wed Apr 04, 2018 7:16 pm
I added a 22 gallon tank and this Sureflo. Runs on 12v and pushes about 3 gallons a minute. I plan on using it for showers and washing but not drinking because it not rated for potable water.Image
Sent from my iPad using Tapatalk Pro
kramergwt
Postby greygoos » Wed Apr 04, 2018 8:14 pm
Having worked with food trailers and clean up of equipment I suggest you carry a 5 gallon hand pump sprayer and use that to wash down your equipment. I don't think the battery operated pumps will give you the right pressure.
greygoos
Postby firemansd19 » Thu Apr 05, 2018 2:25 pm
Unfortunately my tank right now is only about 10 gallons. My first tank (16 gallon) sprung a leak. I will only be using it in short burst when I spray stuff off. I was kinda thinking towards the higher volume also, maybe 3-5 gpm. That will be my next investment.
firemansd19
Postby Socal Tom » Thu Apr 05, 2018 6:16 pm
I use a shurflow. With a garden spray nozzle it’s about like home.
Socal Tom
Postby firemansd19 » Thu Apr 05, 2018 7:25 pm
Socal Tom wrote:I use a shurflow. With a garden spray nozzle it’s about like home.
What is the gpm and pressure rating on it?
firemansd19
Postby Iconfabul8 » Thu Apr 05, 2018 8:13 pm
SHURFLO® REVOLUTION™ Pump 12 VDC 3.0 GPM
Flow Rate GPM/LPM
3.0 GPM [11.4 LPM]
Amps (Max.)
7.5
Shut-Off Pressure
55 PSI [3.1 BAR]
Looks like you should have up to 55 lbs before the pump shuts off.
Iconfabul8
Images: 14
Users browsing this forum: No registered users and 23 guests
