TV Wall Mount
TV Wall Mount
Postby CaptD » Mon Apr 23, 2018 12:37 pm
Is it ok to use one bought at the "club warehouse" or should I buy an RV specific one which I assume is rubber/shock mounted somehow. The tv is an electric version not a 12 volt model. CaptD
2015 Pro Line 7x7x24
2001 Ford E 250
2011 WR 250R
2007 KLR 650
2007 TW 200
CaptD
Re: TV Wall Mount
Postby flboy » Mon Apr 23, 2018 12:56 pm
CaptD, I used a mount that you would use in the house. Just be sure to use good lag screws into something substantial like a wall stud and use a mount where the TV is at the light end of the wieght the mount can handle. I also strap the TV to the wall for travel so it cannot extend out and bounce around where the leverage is increased.
I have not had any issues bouncing for miles down dirt roads in Ocala NF.
BtW, getting a KTM-690R by Dec. this year to outfit. Starting the TAT in June next year with my brother. Going from NC to OR and will ship bike back after riding it up to Seattle and visting nephew. When are you going?
I also will have it with me for the RTR in Quartsite,Az in Jan 2019 if all goes as intended. I plan on hitting the road then and staying out for a few months until close to TAT time. Starting the planning now and finishing up the CTC " odds and ends".
Don (Flboy)
https://youtu.be/6_-8cVdWUIA
https://youtu.be/MUcMM86LA2g
flboy
Images: 378
Re: TV Wall Mount
Postby Sparksalot » Mon Apr 23, 2018 1:18 pm
I used a standard wall mount for mine. The caveat is to make sure the TV can't just bounce out of the bracket. Mine did the first trip, so I wedged a piece of pool noodle above/behind the TV to set it in the mount.
Sparksalot
Images: 682
Re: TV Wall Mount
Postby Iconfabul8 » Mon Apr 23, 2018 9:40 pm
Screwed mine solid to the wall. Definitely not for everyone but worked for me.
TV mount
Iconfabul8
Images: 14
Users browsing this forum: Bing [Bot] and 8 guests
