hankaye wrote:back4more, Howdy;
Welcome to the maddness , .
If you have the factory vents 1 in front (upper), & 1 in back
opposite side (lower), then you might install some computer fans
on the inboard section of them to create a larger volume of moving
air. Just be sure to weather proof the wiring connections.
hank
back4more wrote:hankaye wrote:back4more, Howdy;
hank
Thanks hank. I ordered a Weeroll Nomad and they do not come with the vents you mentioned. I did think about ordering a couple from Amazon though. I like you idea about the computer fans !
onehoser wrote:my roof vent won't clear the garage door either so i installed a pair of spare 5.30x12" wheels i have to get it down low enough. i also use one of the 5.30x12" as a spare tire, it takes up much less room in the trailer and will at least get me home or to a repair shop much like the 'donut' spares new cars come with
Padilen wrote:I gave up and ordered a roof fan/ vent. I have no clearance now so I'm thinking of just rolling it in in the hubs
As is I deflate the tires to get it in or out. Would that give you clearance with a roof fan?
