adding an awning to a cargo conversion
Re: adding an awning to a cargo conversion
Postby yycwrangler » Fri Jul 20, 2018 8:07 am
Pheonix
I see you were in the same situation as I am..Short distance between the door and awning..
I'm trying to get a copy of the RV awning mount instructions for Aleko if anyone has seen one on line.
Flboy if I couldn't use brackets to raise the height, what about mounting some brackets then mounting a horizontal piece of aluminum all the way along the brackets that the awning rail could be mounted to. The other question I have for you is how the arms secure to your trailer. Can those be moved to stand vertical or is there an option to add vertical poles to the outsides to raise the height of the outside of the awning so its close to the height of the trailer and allows the door to open and close
Al
yycwrangler
