I need some help with my propane lines. Currently I have 3 appliances that require propane. The furnace, cooktop, and water heater. The cooktop has a built in regulator but the furnace and water heater do not so I’ll have to make sure I install a low pressure regulator for those. Anyone have any pro tips for how I should run these lines? I was thinking of having one line with a regulator ran from the front of the trailer underneath and up to a central point. From there I could branch it off and have 3 separate lines go to each appliance. Does that make sense or is there an easier way to go about this?
