phoenixbound wrote:How often should the CTC wheel bearings be repacked? I have had a trip to Phoenix and back plus a roundtrip to Sturgis. A total of about 5,000 miles so far.
Tigris99 wrote:all modern vehicle have sealed bearings. Nothing uses those types of bearings anymore.
As for trailer repacking, ez lube adapters are for boat trailers to keep water out (means using marine grease). It can cause more issues for the sake of convenience on bearings using regular grease because regular axle grease degrades in water rapidly. Letting water in past the seal because using that cap pushes grease through the seal also damaging it. The reason why it was never available on vehicles that use the same bearing design. Not opinion, fact there.
Especially just pushing more grease in every year and hoping for the best. Along with most of the contaminants that get in there stay in there.
All of that makes people ignore the hub seals which turns into burned up bearings, races and such one day going down the road.
If you want to use those caps, need to use proper marine grease.
As for when to repack, that depends on the grease used and how well they were packed to start with.
If it's a trailer you bought and never packed them yourself, do it immediately because grease packing at the factory is often poorly done with cheap grease. Beyond that if done with good synthetic grease and done PROPERLY a couple years worth of regular use isnt a problem in light weight trailer purposes. There is an entire procedure for packing and installing that type of bearings, not done right you will have issues. Those that have bearing problems and all that dont do it correctly, that's why and the only reason why they fail.
Make sure before leaving for a long trip you inspect for movement in the wheel (jacking up axle so tires arent touching the ground). if there is any the bearings need to be taken out, cleaned and repacked and properly reinstalled.
Once a year pull the caps (if you do serious miles) and check the condition of the grease.
Sent from my SM-G950U using Tapatalk
