A big skylight will be super hot until the sun sets. Just have a cover over it until dark.
Tt
Tomterrific wrote:A big skylight will be super hot until the sun sets. Just have a cover over it until dark.
Tt
beachguy005 wrote:I guess if you're going to consider all options I'll add this to the conversation. Maybe you should spend the extra money and get a fixed roof skylight with a flange. Low E laminated glass with a hail warranty.
https://www.homedepot.com/p/VELUX-22-1- ... /202844231
aggie79 wrote:beachguy005 wrote:I guess if you're going to consider all options I'll add this to the conversation. Maybe you should spend the extra money and get a fixed roof skylight with a flange. Low E laminated glass with a hail warranty.
You could probably still get this to work, but Velux says there is a minimum 3:12 roof pitch required for this skylight.
beachguy005 wrote:I don't think the flat roof is really an issue on a trailer as it's not on a fixed pitch, nor is there an issue with snow. I can understand those requirements on a building roof, but how often are you actually level when parked? Also with a trailer you can always pitch a few degrees if rain run off becomes an issue. You can't with your house.
