Need help pricing trailer. It got titled and weighed today. 2180 lbs. Trailer is a 2018 (titled as a 2019) 6 x 12 V nose Deep South trailer with a 3500 lb brake axle and spare tire. Side and rear bar lock doors. Side door has interior lock latch to keep it secure while you're in it. 30 amp electrical service with power cord provided. The trailer can easily be run be on a 2000 watt generator as well. Front kitchen area has a sink with both city water and on board water supply (14 gallons), dual fuel (propane & butane single burner stove) and a 3.2 cu.ft. refrigerator/freezer (draws only 0.8 amps). The bed pulls out to a full size bed with a 6" memory foam futon mattress. There is storage under the bed as well. 21" led tv with amplified antenna. 6050 btu air conditioner (draws 5 amps/540 watts). Interior led lights powered by a 35 watt roof mounted solar panel and 20 amp hour battery with a 10 amp charge controller. Rear doors open to provide secure storage for battery, spare tire, antenna, jack stands (included). I still need to put in vinyl flooring (this weekend). I would really appreciate you're thoughts on this. Trailer is located in Oklahoma City. Thanks
