new upgrades to my trailer
Postby jwhite » Wed Jul 31, 2019 9:45 am
I did some new upgrades I wish I had done a long time ago one was I added some new awning material to the side of my trailer, I don't have a awning but I had puts some bolts through the side of the trailer and used just a tarp and it looked so home made,
I went on ebay and found just awning replacement and it looks great I have to use a step stool and hand roll it up and stake it down but it look 100% better, I have actually been thinking about putting another on the other side of the trailer.
I also installed a power jack and that is something I wish I had done years ago the hand crank go to the point it didn't hardly work, it was the best money I could have spent, I have rear stabilizers but never used them now it's so easy to lower the front down and put down the rear jack and power it back up rock solid.
last I bought a battery powered gas pump that that drops down in the gas can and with the flip of a switch fills my generator.
I just wonder why I hadn't done this before ?
jwhite
Images: 46
Re: new upgrades to my trailer
Postby Grummy » Wed Jul 31, 2019 12:23 pm
jwhite wrote:.....last I bought a battery powered gas pump that that drops down in the gas can and with the flip of a switch fills my generator.
Do you have a brand or link for the pump you bought ? I once bought one to transfer Kerosene, but I would not use it on gas simply because it was an open framed brushed motor that arc'd enough to ignite fumes.
I've seen some people discussing using a pump like this for gas... but curious what pumps are being used, and also if actually approved for gasoline.
Grummy
Images: 104
Postby jwhite » Wed Jul 31, 2019 12:50 pm
jwhite
Images: 46
Postby beachguy005 » Wed Jul 31, 2019 8:18 pm
Just as an aside, a great tool for transferring fuel is one of the siphon hoses. I call it a shaker hose. Used them for fueling boats and they work great. It's just a no suck siphon hose. Give it a few shakes and it runs fluid from on container to another.
https://www.amazon.com/Safety-Siphon-Sa ... way&sr=8-3
beachguy005
Users browsing this forum: Google [Bot] and 18 guests
