Gas spring question
Gas spring question
Postby Carolina_coast99 » Tue Sep 03, 2019 3:22 pm
Hello,
I'm trying to decide what type of gas spring I need.
They (2) springs will assist in "opening" the top part of my bed housing. Underneath will be storage area.
It will be a king mattress resting on a 3/4" plywood, 2x4" framing, with a piano hinge attached along the long edge of the mattress board. So, I will be raising the bed longways on the hinge with assistance from the springs. [A spring will be at the head and one at the foot of the bed]
I'm not sure:
What length (extended and compressed)?
What extension force...?
I attached what I am thinking I may need...
https://www.mcmaster.com/gas-struts
Not sure this is the full location for what I want but the part number is: 4138T58
Help is appreciated!
Carolina_coast99
Re: Gas spring question
Postby dirtsailor2003 » Thu Sep 05, 2019 10:50 am
There's numerous calculators online that can help you in calculating what you need. This link will give you a good idea of which type to order for your application and give you an idea of what numbers you'll need for using a calculator.
https://www.dictator.nl/Downloads/EN/Re ... prings.pdf
dirtsailor2003
Postby Carolina_coast99 » Sat Sep 07, 2019 8:08 am
Ok- thanks dirtsailor
Carolina_coast99
