Welcome!
Here's a discussion on Trailer Showroom, basically an online broker for several different manufacturers. Folks here seem to have had an overall good experience with them.
http://tnttt.com/viewtopic.php?f=42&t=70139Looked at your 7x12 thread, that transition from tent to small toy hauler, without all the fancy kitchen/bath stuff sounds familiar. Real familiar, just like ours. With a screen name that hints "kayaker", well, here's ours for ideas.
http://www.tnttt.com/viewtopic.php?f=42&t=48345I find the search feature here a little overwhelming, so here's a copy/paste from another related post:
Here's one of the Cargo Craft 6x14 offroad trailers:
https://www.youtube.com/watch?v=eqZQptdGU4g&list=PLuuocdv6wv7jHQKayvM-yYkJiB-ULrtRT&index=1The models featured above are built by Cargo Craft of Texas, they also have a Georgia plant in Ambrose. I imagine they can build the same models in Georgia. Mine is a Cargo Craft as well, fairly happy with them as far as cargo trailers go. Good build for the price, still a family owned business.
-always order the next size up (2' longer) than you need
-consider having windows factory installed and offset for airflow, (credit gonefishin).
-same for a quality 36" RV-style side door
-put the fantastic vent fan into one of the ceiling vents.
I ordered a tandem even though I knew I'd never need the weight capacity. Reasons; "crawl" over bumps vs bounce/jump of single axle, get a flat, and keep going to a safe spot to change it, If I do need to carry heavy, well, I can. Of course doesn't turn as easy, but is more predictable backing up, and runs great on the road heading to the camping spots, not bad on the forest road. I chose standard leaf spring for more ground clearance.
Here's another good discussion on choosing a trailer:
http://www.tnttt.com/viewtopic.php?f=42&t=54375=========
In your case, for stability, 4 stab jacks have worked great for me, combined with some 4 x 6 blocks for certain spots. Also, consider standard spring axles for greater ground clearance for those occasional forest service road trips. Single step welded from factory at RV door, a big plus.
Edit: since you posted you are in the Southeast US, consider finding a local dealer for a brand you like, work a custom order with them, following it through with step-by-step updates/approvals.
East Tennessee area, I like Homesteader. I talked to these folks near Knoxville, TN on behalf of a friend, they seemed pretty knowledgeable on handling a custom Homesteader build.
https://us.tngolfcart.com/cgi-bin/f/trailers.plGeorgia, etc. well, I'd probably do another Cargo Craft, simply due to their support after the sale. I used Dykes Creek Farm Supply/Mathis Trailer and Equipment in Kingston, GA near Rome.
Several decent brands, I guess the difference being their willingness to customize at reasonable costs, communication via the dealer, and support after the sale, (which is not common in the cargo trailer world).
Best,
David
