I'm building a "work/sleep" CT for a guy and he just hit me with 'let's put solar on it". He bought a 2 - 250 watt panel kit from San Tan Solar. Kit includes 2 - 250 watt panels, 50 amp MPPT Controller, 10 gauge wires from panel to controller and enough 10 gauge to run from controller to batteries (I'm thinking change that to 8 gauge) and a 60 amp circuit breaker. He is connecting to an AIMS 1000/2000 watt inverter/charger with an auto transfer switch. What size fuses/beakers are needed? I have limited experience with solar, so I could use some advice The panel mounting and wire running is not an issue for me, but sizing things is. He was "advised" by someone to use 4 gauge wire from battery to battery and battery to inverter. Each run is under 18". He'll be running a dorm frig, lights and charging phone & tablets. From what I've read, I think we need a 60 amp breaker between the panels and controller, 60 amp fuse/breaker between controller & batteries and 175 amp breaker or 200 amp fuse between batteries & inverter. any help will be appreciated. Thanks
