I’ve not had any issues so far knocking on wood. I’m not running lead acid batteries so I can’t speak to that portion of it. Yes it’s rated at 33.4a at 15v. Since I’m running it at 14v I get a little more out of it. I’m getting a consistent 40.5A from mine without triggering the protections.
There are 100’s of different meanwell power supplies. Something doesn’t seem right.
Come to think of it I haven’t seen the power supply taper off much as voltage increases. Maybe it has to do with the fact the bms charge cut off is lower than the power supply out put
