tibx wrote:Will cutting the flanges negatively impact the structure of the crossmember?
tibx wrote:My haulmark transport has 16" OC u channel metal crossmembers. This flange design only allows 13 ¼” distance between flange material. Looks like I need to have 14" to install a fantastic fan. I would have to cut into the crossmember flange metal to get 14". Will cutting the flanges negatively impact the structure of the crossmember?
Sparksalot wrote:How wide are the flanges in question? What is the arrangement, meaning would you trim both side equally?
