The fire/hunt trailer
Posted: Mon May 30, 2022 4:50 pm
New guy with a new build. I have been reading here for a while. The bug has bitten. I purchased a second hand 6x12 premier cargo trailer. It is in very good shape, with a spare tire and a tool box on the front.
This build will have two purposes,
#1 - for hunting
#2 - a place to rest when out on wildfires.
I got it home and, the first thing I did was an axle flip. Big mistake, I forgot how many times you will have to climb in and out during the build. But it will be a good thing when I am done. Should have been the last thing to do. So the steps are ordered and on the way.
Now to start on taking out the inside plywood . This opened up a whole new can of worms . And now it is time to go fishing, I mean to fix things. When I took the front off, there was a big gap in each corner. I could slide my hand up in there when I was laying on the ground. Took floor out in front cut and trimmed till I had better fit. It took most of the day . Working on sealing the bottom and putting back in and caulk everything up. Will work from the front to the back on the floor. Then insulat the trailer.
It will be slow to start with, waiting on steps as I will have to cut and reweld the frame ,to fit the steps. Then thing should go faster.
#1 - for hunting
