doug hodder wrote:Gus....I'd double think the hinge at the end of the iron.....................................
Here are my thoughts:
All waffle irons have the hinges at the opposite end of the iron from the handles.
All of the Pie Iron products have the hinges opposite the handles.
http://www.pieiron.com/designs.htmNo matter where the hinges are, if you pour batter in both halves yer gonna have to be a bit creative in closing the iron while not spilling the batter out. Maybe a little bit more awkward with the hinges at the end but I don't think it's a that major a deal.
I've watched the videos of youse guys using the original waffle dog irons and seen the efforts, such as using vice grips, to keep the irons closed while in use. I think having the hinges opposite the handles would help a lot.
It does make the assembly twice as long when open but the closed length of the waffle iron would remain the same. I think the improvement in keeping the iron closed during use would be worth dealing with the additional length when open.
I agree being able to heat both sides at the same time is a plus but the waffle dog iron is the only item of this type that has that feature. You can't do that with the PieIron products or waffle irons (unless you take the waffle iron apart and heat the halves on two separate burners.
I'll poke around a bit more this week. Getting the castings ($50 a set) isn't a big deal. Then you have to add the handles,drill out the hinges, and rivet the halves together. I think having jigs would make doing a lot easier and ensure the job is done right but I don't have the energy to make em right now.
Cheers,
Gus
