Trouble brewing... Prime rib
Postby citylights » Fri Mar 14, 2014 4:32 pm
So here is the ultimate pressure situation / disaster in the making!
I do all the cooking in my family, and I have always done about 90% of it in the BBQ or flat iron grill that I have outside. I think I am a good BBQ chef, but I got into DO cooking about 2 months ago. I have had great success and fun cooking in them for my family. Well everything except the cast iron skillet seasoning, but that is another thread...
So for tomorrow, we invited 6 friends over for dinner and I am cooking in the Dutch ovens for friends the first time AND I am cooking something I have never done before!
Cooking rice stuffed bell peppers. That's a snap, did it great just last weekend. :thumbsup:
Cooking chilli beans. Another slam dunk, it's already made and they turned out awesome, if I do say so myself. I just need to heat it up in the DO. :twisted:
Of course we will have a green salad.
And... I am cooking a prime rib. I have done those great in the oven, but never in a DO. I am thinking just a simple salt and pepper rub, preheated deep 12-inch DO blazing hot to start, toss the prime rib in, then reduce coals to get about 325 at 15 min per pound. 6 pounds, that's 90 minutes, I realize I am going to have to refresh the coals at about 45 minutes. When done, remove meat and prepare AuJu with the drippings in the DO. :thinking:
Will that work?
Any hints, secrets, or prime rib recipes you can share with me?
citylights
Re: Trouble brewing... Prime rib
Postby MtnDon » Fri Mar 14, 2014 5:12 pm
Brave man... I experiment on the immediate family and only serve company what's been tried and true. Sorry, no suggestions though as I've neber done one of those. Best o' luck.
MtnDon
Images: 24
Postby mikeschn » Fri Mar 14, 2014 5:27 pm
This is the way I do Prime Rib... http://chefbolek.blogspot.com/2010/12/b ... roast.html
I would experiment with the DO's to get the temps right... Too bad you don't have time to practice. :(
Images: 479
Postby citylights » Fri Mar 14, 2014 6:56 pm
Oh, come on where is your sense of adventure? I have never met a prime rib that wasn't delicious!
The only thing I am worried about is it not being done at the right time because of bad temperature control. I have a solution for that too.... Slice and sear on the flat iron grill!
citylights
Postby PKCSPT » Sat Mar 15, 2014 6:14 am
I just want to know what time do I need to be there, :Flippin Burger:
I make a goooodd guinea pig when it comes to prime rib
121172 116946 159644
PKCSPT
Images: 61
Postby eamarquardt » Sat Mar 15, 2014 10:15 am
You might consider using a meat thermometer.
Hope this helps.
Gus
eamarquardt
Images: 150
Postby citylights » Sat Mar 15, 2014 12:24 pm
eamarquardt wrote:You might consider using a meat thermometer. Gus
Yes! I wouldn't consider cooking a prime rib without one.
citylights
Postby citylights » Sat Mar 15, 2014 3:19 pm
Tonights, mission impossible!
It actually fits, the picture is deceiving...
citylights
Postby mikeschn » Sat Mar 15, 2014 3:27 pm
John, We need a side view of those ribs... ;)
Images: 479
Postby citylights » Sat Mar 15, 2014 11:30 pm
The prime rib turned out good, but I blew it. We got talking and it cooked 20 minutes too long. That turned the prime rib into a really nice roast beef.
Next time, set the timer!
Also, I used a small meat rack / trivet, but it is really to shallow. Next time I need to drain off some of the juice half way through.
citylights
Postby bdosborn » Sun Mar 16, 2014 12:54 pm
Cloud Maker Ranch Prime Rib: http://youtu.be/DmW0CAsnXaoh
From Dean and Joanie
Images: 778
Postby warnmar10 » Thu Mar 27, 2014 9:24 pm
bdosborn wrote:Cloud Maker Ranch Prime Rib: http://youtu.be/DmW0CAsnXaoh
An old family favorite around here.
"When a true genius appears in the world, you may know him by this sign, that the dunces are all in confederacy against him." - Jonathan Swift
warnmar10
Postby bobhenry » Fri Mar 28, 2014 7:44 am
I have found several sizes of these little collanders at Goodwill for a buck or two.
Some have feet, some just have dimples, and some are flat on the bottom. If I want my meat to drain well I simply chuck 3 balls of aluminum foil under this make shift trivet and it drains away with no possibility of burning on the bottom.
Images: 2617
Return to Cast Iron
