Yet more new bikes.
Bicycles for campers, rvers, or just riding around where ever you are
Yet more new bikes.
Postby Fenlason » Fri May 13, 2016 6:36 pm
There have been many bikes on my radar.. but we were not going to get any this year. I had purchased the Krampus about a year ago.. and am really loving it. I did recently get one for my wife. Her's will be keep the flat bars vs the drops. While loving the drop bars on mine, I have been intrigued with the flat bar version.. really wanted one.
I am not sure what Surly is doing bike wise.. they are running much of their inventory down.. and marking stuff down. They had no Krampus in my size. I have lusted after their Ice Cream Truck since it came out. They were 25% off and I had worked extra at work soooooo…. :twisted: The Ice Cream Truck is a super fat bike like the Moonlander. 4.8 inch tires on 100mm wide rims. The ICT is not an asymmetrical bike like the Moony and Pugs. It has a much stiffer frame and more modern trail bike geometry. It has through axles, and has suspension compatible geometry. I could also put 29er + wheels like the Krampus. Although I would have to build a new set. for the ICT has much wider hubs than the Krampus.
I just got it built today… and I went for it's first ride this afternoon. It's a pretty sweet bike… I still have a few things to adjust.. fit wise and such. It is yet to be determined if I will keep all 3 fat bikes or not.
glenn
Kahlil Gibran
George Bernard Shaw
Fenlason
Tour de Post Yellow Jersey
Images: 221
Re: Yet more new bikes.
Postby Greg M » Sat May 14, 2016 11:50 am
I too was trying to hold out, but then a friend of mine gave me this:Image
I'm going to need a storage building at this rate.
Greg M
*Geek Extraordinaire
Images: 85
Postby Fenlason » Sun May 15, 2016 6:21 am
Greg M wrote:I too was trying to hold out, but then a friend of mine gave me this:Image
Wow! That is pretty incredible. Nice bike. :D
My space is getting tight. I am doing serious work on it this year. I have 3 roofs that need replacing.. among lots of other work… and some clean up and organizing.
glenn
Kahlil Gibran
George Bernard Shaw
Fenlason
Images: 221
Postby kirkman » Sun May 15, 2016 8:43 am
kirkman
Images: 55
Postby Fenlason » Mon May 16, 2016 4:50 am
glenn
Kahlil Gibran
George Bernard Shaw
Fenlason
Images: 221
Postby Fenlason » Mon May 16, 2016 5:00 am
Laurie's new Krampus on the left.. mine on the right.
glenn
Kahlil Gibran
George Bernard Shaw
Fenlason
Images: 221
Postby Fenlason » Mon May 16, 2016 5:12 am
Laurie's is mostly stock [so far anyways]. Her's is a 1x and I switched out the 34 tooth front ring for a 30 wide/ narrow that I had on hand. I also cut her bars a little, although it needs more.
My Krampus… has had much for changes. I have a Woodchipper dropped bar, and a different stem so that fit is better. A lighter more comfortable carbon seat post I had on hand, and a lighter racier seat [also from my stock]. 10sp Dura ace STI levers [off my road bike.. which I upgraded to 11sp]. I switched out the single crank for a double.. and of course added a front derailleur. The rear derailleur needed to be switched out. Newer Shimano mountain derailleurs aren't compatible with the road shift levers. I had an older XTR derailleur that was. I also had to switch out the brake calipers, road and mountain have different cable pulls, so while having to switch I also upgraded to the new TRP calipers.
glenn
Kahlil Gibran
George Bernard Shaw
Fenlason
Images: 221
Postby Fenlason » Sun Jul 24, 2016 12:46 pm
I have ordered wheels for my Ice Cream Truck. I want to try 29er+ on it. The 29er+ Wheels from my Krampus won't fit. The ICT uses a 150mm front hub vs the 100 on the Krampus. It also uses a through axle. The rear uses a 197mm through axle vs 135 regular q-release.
The wheels I ordered use DT Swiss. I opted for a WTB rim vs the Surly Rabbit holes.. despite the RH being on sale. The WTB rims set up tubeless much easier.
I was hoping to receive the wheels Friday, but tracking says Monday. [although later Monday] Hopefully I can get them set up before our Monday night ride.
Once I get my wheels I will check their clearance on the Bluto fork. If they fit ok, I suspect I will also get one of those.
glenn
Kahlil Gibran
George Bernard Shaw
Fenlason
Images: 221
Postby cigarsnjeeps » Sun Jul 24, 2016 5:43 pm
Cool. Post up when it's complete. Would like to see it.
Sent from my LG-H900 using Tapatalk
cigarsnjeeps
Postby mikeschn » Sun Jul 24, 2016 6:04 pm
So what are we up to? 50?
Images: 479
Postby Fenlason » Mon Jul 25, 2016 4:38 am
cigarsnjeeps wrote:Cool. Post up when it's complete. Would like to see it.
Will do. :thumbsup:
glenn
Kahlil Gibran
George Bernard Shaw
Fenlason
Images: 221
Postby Fenlason » Mon Jul 25, 2016 4:40 am
mikeschn wrote:So what are we up to? 50?
I don't really know any more... :oops:
I do need to get ride of some.
glenn
Kahlil Gibran
George Bernard Shaw
Fenlason
Images: 221
Postby Fenlason » Fri Jul 29, 2016 6:08 pm
I finally got my wheels [and such] for my Ice Cream Truck.
glenn
Kahlil Gibran
George Bernard Shaw
Fenlason
Images: 221
Postby cigarsnjeeps » Fri Jul 29, 2016 6:13 pm
Nice. I sometimes miss my hardtails, but my back can't handle it. My new Hightower is great except I seem to have more pedal strikes now because of the low bb height. We have alot of rocks around here.
cigarsnjeeps
Postby Fenlason » Fri Jul 29, 2016 6:20 pm
I have DT Swiss hubs. WTB i45 Scraper rims, and Maxxis Chronicle tires.. set up tubeless. The main reason I went with these rims vs the Rabbit Holes [that are currently on sale] for their ease in setting up tubeless. I used WTB tape and valves. I first inflated them without sealant.. and they inflated as easily as if they had tubes. I put new brake rotors on these wheels. It will make the seasonal change over easier, but the biggest reason was at the moment I could only get the hubs with center lock rotors vs the 6 bolts set up of the stock hubs. So basically I will just need to switch over the cassette when I switch the wheels out.
I am debating getting a pair of 5" studded Dillinger tires for it, and let this bike become my regular winter bike.
My Pugs is normally my go to snow bike, and when I really need the float.. I use the bigger tired Moonlander. So maybe my ICT for my go to bike.. and when there is a lot of softer snow.. I can ride my Moonlander with Lou and Bud tires, and platform pedals [vs my normal step ins.]
I am not sure If I will try a suspension fork on this or not.
glenn
Kahlil Gibran
George Bernard Shaw
Fenlason
Images: 221
Return to Bicycles
