space saving furniture
Re: space saving furniture
Postby droid_ca » Fri Sep 07, 2012 10:21 am
Yet another great idea I like the counter as I can see many possibilities with a counter like that even if its up and you place it down it could be good for a wrap around kitchen and use it as a breakfast bar or just like you said more counter space sometimes those big meals can take up alot of space great idea Bob Henry :thumbsup: :thumbsup:
“Fide Canem”
viewtopic.php?f=5&t=52816
droid_ca
Images: 176
Postby Engineer Guy » Wed Oct 10, 2012 8:34 am
While my future Build of some Decade will have the usual Cutting Boards that go over a Double Sink, there's a neat, parallel idea I saw while traveling.
While visiting the DESY Research Accelerator in Germany, the American 'running' the operation had the usual splay of Papers and items all over a large Table. He pulled out a nice piece of Birch Plywood with 4 hard Rubber Feet on the corners. He set it down over the mess of Papers and - ta da - we had '2nd Story', clean surface to set Product Samples on. This same idea could be used in any Build to create 'new', temporary Counter top.
Engineer Guy
Images: 118
Postby bobhenry » Tue Oct 16, 2012 7:06 am
Here is a dizzying display of bed ideas.
http://www.flyingbeds.com/
Images: 2463
Postby droid_ca » Tue Oct 16, 2012 8:50 am
bobhenry wrote:Here is a dizzying display of bed ideas.
Thanks for sharing that gives some good ideas
I like Sue's Bar Bed
“Fide Canem”
droid_ca
Images: 176
Postby bobhenry » Tue Nov 13, 2012 10:49 am
Here are some more neat ideas.......
This little spice rack is supported on 2 cut to fit tension spring style curtain rods and a small piece of light paneling
This disappearing storage shelf would be great for folded clothes and linen and anything else you can think of.
tired of trying to reach the back of the lower cabinets let them come to you.
I can never find the right measuring cup this will organize them!
A no waste storage idea a great place for the grocery list
Yet another gravity feed can dispenser !
Images: 2463
Postby droid_ca » Tue Nov 13, 2012 11:41 am
bobhenry wrote:Image
I like this idea I may have to consider something of the sort
now what about attaching cushions to the top of those slideouts and you have instant seating no need to have extra chairs to get in the way
“Fide Canem”
droid_ca
Images: 176
Postby loaderman » Mon Nov 19, 2012 1:59 pm
seat cushions could be a great idea. may also want to add drop down legs, or slide blocks under the edge for support.
loaderman
Postby loaderman » Mon Nov 19, 2012 2:03 pm
My biggest space saving idea is what I call Bathroom in a cabinet.
Basically build a cabinet with a toilet on the bottom that slides out.
Then a drawer for storage.
then a sink above that which may or may not slide out.
then cabinets above that.
Shower pan would be in the floor infront of this cabinet and covered with a panel. And either have walls that flip out around it or a curtain hung from the ceiling which the track would go back into the cabinet. This area would be part of the main area or a hallway.
Entire bathroom would only take about 18" or 24" deep and 32" wide.
loaderman
Postby droid_ca » Mon Nov 19, 2012 6:04 pm
loaderman wrote:seat cushions could be a great idea. may also want to add drop down legs, or slide blocks under the edge for support.
I was thinking of open bottom and have castersfor support just use the drawer slides as guides basicly
“Fide Canem”
droid_ca
Images: 176
Postby loaderman » Mon Nov 19, 2012 6:51 pm
good thinking. it'd work great
loaderman
Postby droid_ca » Tue Nov 20, 2012 12:41 am
loaderman wrote:good thinking. it'd work great
Just wait till I release a few of my other secret ideas in my build thread I'm doing a small cabin style build that isn't cramped but has everything...and then some
“Fide Canem”
droid_ca
Images: 176
Postby bobhenry » Tue Nov 20, 2012 9:49 am
Speaking of casters I have been scouring 3 different goodwill's for a couple of skate boards. I want to remove the trucks and mount them on the bottom of the dividing walls for the bottom rollers. I caught a glimps of 2 but both were in tow under the arms of 10 - 12 year olds :x
Images: 2463
Postby loaderman » Tue Nov 20, 2012 8:24 pm
:twisted: you could take them! :lol:
skateboard trucks (wheels) are a great idea.
Droid - do you have a build thread? Always want new innovative ideas.
loaderman
Postby droid_ca » Tue Nov 20, 2012 11:18 pm
loaderman wrote:Droid - do you have a build thread? Always want new innovative ideas.
Yes I do it is in my signature it's called Rob's Cabin
“Fide Canem”
droid_ca
Images: 176
Postby bobhenry » Mon Nov 26, 2012 2:34 pm
Here is a novel idea for cleaning supply storage.
Images: 2463
