What am I missing?
What am I missing?
Postby prohandyman » Thu Jan 15, 2009 7:25 pm
The pump on my Kampkook has a "grease-zerk" like fitting on the end of the pump, and the tank has a "cup-shaped" recess. Is there anything to connect the two, or do you just use hand pressure to hold the two together as you pump up the pressure? I don't have any instructions for the stove!
I am trying for super bowl "light-up"!
Dan
prohandyman
Images: 785
Postby rainjer » Thu Jan 15, 2009 7:43 pm
Can you post a picture?
Jeremy
rainjer
King Koleman
Images: 11
Postby doug hodder » Fri Jan 16, 2009 10:16 pm
A pic would be helpful Dan...I can't see what's going on in the pics that you have in your album. Show your entire tank as well as the pump. It looks a lot like a Prentiss Wabers stove, similar to the one I have marketed under the Sears name, however the tank setup appears to be entirely different. Doug
