Side by side burn
Side by side burn
Postby rainjer » Thu Jan 22, 2009 10:11 pm
I did a side by side burn of my 502 stove & 500A stove tonight.
The 500A (left stove) puts out a lot more heat than the 502 stove. I am very impressed. Both put out a good amount of heat. I don't think I will have any problem making waffles on either one.
The strange thing is I put t he same fuel in both stoves & the flames are very different colors.
Jeremy
rainjer
King Koleman
Images: 11
Re: Side by side burn
Postby Nitetimes » Thu Jan 22, 2009 10:13 pm
rainjer wrote:I did a side by side burn of my 502 stove & 500A stove tonight.
Jeremy
Something to do with what the burners are made out of? maybe?? :thinking: :thinking:
Rich
- Thomas Jefferson -
Nitetimes
7000 Club
7000 Club
Images: 194
Postby rainjer » Thu Jan 22, 2009 10:15 pm
Both burners are made up of steel rings. Maybe more air?
Jeremy
rainjer
King Koleman
Images: 11
Postby hotrod » Thu Jan 22, 2009 10:45 pm
the one on the left looks like its burning more fuel, I bet if you filled them up equally and ran them wide open till empty the one on the left would run out first! Maybe there is a different sized valve between the two??
Paul
hotrod
TILT
TILT
stove
Postby doitright » Thu Jan 22, 2009 11:15 pm
They look great. :applause: :applause: The 500A looks as if it is larger and a larger tank than the 502. I bet it will be sturdy for the waffle iron.
doitright
REAR DOOR CAMPER
1959 REAR DOOR SCOTTY
doitright
Images: 38
