Now Working?? SGT BILKO LANTERN!!! Look Alive Doberman!!!
Re: Now Working?? SGT BILKO LANTERN!!! Look Alive Doberman
Postby Wolffarmer » Wed Jun 12, 2013 1:24 pm
There are only 3 changes I have seen. From single piece globe to the quadrants, a different method of clamping down the burner tube to the base. And the SMP painted vents. Then it seems they just started buying 290s or something like that, no quadrant globe. Probably just tossed them if it got busted.
Randy
Wolffarmer
Images: 309
Postby SuperShady1 » Wed Jun 12, 2013 2:41 pm
Wolffarmer wrote:There are only 3 changes I have seen. From single piece globe to the quadrants, a different method of clamping down the burner tube to the base. And the SMP painted vents. Then it seems they just started buying 290s or something like that, no quadrant globe. Probably just tossed them if it got busted.
Randy
Do you have a favorite??
I like the single mantle from 1952.
Its a beautiful world we live in
A sweet romantic place
Beautiful people everywhere
The way they show they care
Makes me want to say
For you, for you, for you
Coleman Keepers 200A Gang
SuperShady1
Images: 318
Postby Wolffarmer » Wed Jun 12, 2013 4:46 pm
My 58 Coleman is nice. Was almost unused when I got it Dec 2011. Nice, clean, bright, has the single piece globe with proper lettering for a Mil Spec. Came with the box, a bunch of extra generators, the tool. Paid $19 for it.
Got all those lanterns at an estate sale for $57. I went back a few hours latter and got a barely used 426B for $30.
Randy
Wolffarmer
Images: 309
Postby SuperShady1 » Wed Jun 12, 2013 6:10 pm
Wolffarmer wrote:My 58 Coleman is nice. Was almost unused when I got it Dec 2011. Nice, clean, bright, has the single piece globe with proper lettering for a Mil Spec. Came with the box, a bunch of extra generators, the tool. Paid $19 for it.
Randy
wow those are beauties!!...love the amber globe on the 200A and the chrome looks so nice...wow what a find!!
I am sure the 426b is a stunner as well.
Shady
SuperShady1
Images: 318
Postby Zollinger » Wed Jun 12, 2013 11:10 pm
You SUCK Randy! :R
Dawn
Green Lantern Corpswoman
Zollinger
Images: 64
Postby Wolffarmer » Thu Jun 13, 2013 7:39 am
Thank you.
The nickel plated one is a 220B from Nov. 1939. With correct globe. I could not tell if it had been restored or had been only fired just a very few times. Being an estate sale nobody there really knew. It looks very cool on my fireplace mantle. As you can see it came in the original box, though it is in rough shape and some of the paper work and some tools.
:D Randy
Wolffarmer
Images: 309
Postby SuperShady1 » Thu Jun 13, 2013 1:24 pm
Wolffarmer wrote:Thank you.
:D Randy
Wow again what a barn find that was..congratulations.
Dave
SuperShady1
Images: 318
Postby campmaster-k » Fri Sep 06, 2013 4:02 pm
I tell you kids and tell you and tell and you just wont listen. Matches, thats caveman days. Lighting lanterns with matches is NOWHERE man. Many a temperamental lantern problem will be solved by simply using a mini torch to start the lantern. That way you can quickly give the generator a warm up before launch. Works like a champ.
Shady one more thing I did not see get mentioned here on the Military. It does not like to play nice with the globe off. That aluminum gen. needs the captive environment to stay hot enough to work right.
Just sayin YO.
-Kirk
>CEO Coleman Recovery Inc.
Build thread -
Check out my Pictures -
campmaster-k
Postby SuperShady1 » Mon Sep 09, 2013 2:05 pm
campmaster-k wrote:I tell you kids and tell you and tell and you just wont listen. Matches, thats caveman days. Lighting lanterns with matches is NOWHERE man. Many a temperamental lantern problem will be solved by simply using a mini torch to start the lantern. That way you can quickly give the generator a warm up before launch. Works like a champ.
Just sayin YO.
I agree on the globe needing to be on to help keep the heat in and warm that generator up. :thumbsup:
I usually just use a fire wand and hope that it catches. I did note about pumping her up then let some fuel into the globe first, then shutting down the valve then lighting and reopening seems to work the best. But I will try a Blow Torch and see how that works. :thumbsup: :lol: :thumbsup: :applause:
Just love the sound of that 252!! 8) :? :shock: 8) :lol:
SGT Shady!!
107405
107407
SuperShady1
Images: 318
Postby campmaster-k » Mon Sep 09, 2013 2:41 pm
Yep the sound is like a little jet engine. Its cool.
-Kirk
Build thread -
campmaster-k
