Leather or rubber
Leather or rubber
Postby KennethW » Sun Jan 31, 2016 10:14 am
I have a old coleman gas stove. I use it a lot. The pump leather broke when streaking it out. For a stove that will be used a lot and needs to work should I get a replacement leather that can be reworked if needed or a neoprene that if broke will not work?
KennethW
Images: 82
Re: Leather or rubber
Postby Dave A » Sun Jan 31, 2016 12:04 pm
it has been my experience that leather if oiled occasionally is a superior pump material especially in cold weather
Dave A
Postby Woodbutcher » Sun Jan 31, 2016 12:21 pm
Ditto what Dave said. Parts can be had here http://www.oldcolemanparts.com/home.php
Woodbutcher
Postby KennethW » Sun Jan 31, 2016 2:03 pm
Thanks,
Leather is what I was leaning toward. The old one lasted over 40 years and sat for 20 plus before I got it.
KennethW
Images: 82
Postby Wolffarmer » Sun Apr 24, 2016 9:36 pm
Leather by all means. I have had to replace the rubber cup on a stove that I only been using for 25 years. The last 5 or so years I had to put a few drops of motor oil off the dipstick to make it work.
Then I discovered Coleman collecting and its been a fast slide into perdition.
Randy
Wolffarmer
Images: 309
