shes tight on a sears.
Postby slowcowboy » Sun Apr 24, 2016 7:29 pm
okay we got a big hat sears and want to pull the valve and stem and vent tubes out of the font. the hole upper works...........how do I loosen it up to break It free of the font...........not sure if pb blaster is working.............any ideas? slow
Plans. there was supposed to be plans to be followed when I built this thing. Opps! AH, gee, tum,tee tum. I think I forgot about the plans 2 years ago. ------Tow vehicles, 1995 ford explore, 1994 ford ranger, 1993 ford F-150, 2009 4x9 Off road teardrop, on harbor freight greatly modified frame.
slowcowboy
7000 Club
7000 Club
Images: 166
Re: shes tight on a sears.
Postby slowcowboy » Sun Apr 24, 2016 7:30 pm
while we are on the sears big hat.............can I get decals for them still and thinking of repainting the font wich is half way livable to not paint. slowowboy
slowcowboy
7000 Club
7000 Club
Images: 166
Postby Woodbutcher » Sun Apr 24, 2016 8:26 pm
When I want to separate the tank from the upper half I put a piece of rubber around the upper right where it joins the tanks an place it in the vice upside down. Then spin the tank off. Every once in awhile I have to but a rubber strap clamp (like you use to spin off an oil filter) and help break it loose. Make sure the rubber strap is on the very bottonm of the tank or you will dent it when pressure is applied.
This place has the Sears Decals.... http://www.oldcolemanparts.com/home.php
Woodbutcher
Postby Wolffarmer » Sun Apr 24, 2016 9:30 pm
I use woodbutcher's method though usually with hunks of wood instead of rubber. Just be careful to not put side ways pressure on the tank or you can easily put a little bend in the area of the bung and later have to bend it back straight. Not to hard to do but a tiny bit of a pain.
Randy
Wolffarmer
Images: 309
Postby slowcowboy » Mon Apr 25, 2016 12:01 am
so basicly protect the font and clamp it in a vise am I understanding you guys right? slow
slowcowboy
7000 Club
7000 Club
Images: 166
Postby Wolffarmer » Mon Apr 25, 2016 2:00 am
I clamp the valve works in the vise. No tight just to hold it as I hand turn the font. Has worked on all of mine. Take what you think is needed off of the valve assemble to keep from damage. I can't remember should be taken off, it has been a while since I worked on double mantle of that era.
Randy
Wolffarmer
Images: 309
Postby slowcowboy » Mon May 23, 2016 10:02 pm
the big hat sears crapped out shes tight on the font because the underside has jb weld all around the inside ring on the bottom of the font. so I think they jb welded the stem on to the font too.............rats! back to eybay!!!!!!!!! slowcowboy
slowcowboy
7000 Club
7000 Club
Images: 166
