Unusual Designs Found on Internet
Awesome PU camper build
Postby WizardOfOdds » Sun Sep 29, 2019 7:25 pm
This is among the most impressive builds I've seen anywhere.
All aluminum (frame & skin) pop-up with bed over cab and bifolding insulated sides.
62 photos show build start to finish https://imgur.com/gallery/RokIb
review at https://gearjunkie.com/custom-pop-up-camper-build
https://i.imgur.com/n8nzkL7.jpg
https://i.imgur.com/0kJAik2.jpg
https://i.imgur.com/NY0XZ3x.jpg
I saw no info on weight or pictures of erection procedure (but the video which I was unable to view might include it).
Entry/exit door does not elevate. Us older folks might find getting in/out of the cab over bed a challenge too.
Attractive interior, no toilet or shower.
Not sure how well sealed all those folds hold up against blowing rain, or what it cost, but if this becomes a popular build, buy stock in whoever manufacturers those long piano hinges!
WizardOfOdds: Chalet shaped rag roof clam shell TIER drop for 4 cylinder tow
Tip Top Tier Drop thread http://www.tnttt.com/viewtopic.php?f=5&t=56232
Unusual Designs thread http://www.tnttt.com/viewtopic.php?f=5&t=64495
Tale of 2 Trailers thread http://www.tnttt.com/viewtopic.php?f=35&t=61451
WizardOfOdds
Images: 44
Re: Unusual Designs Found on Internet
Postby Louisd75 » Tue Oct 29, 2019 9:48 pm
Here's one that popped up for sale near me. It looks like a 4x8 or smaller built offset on the trailer deck. The space leftover on the deck will fit a motorcycle:
159896
159897
Louisd75
Images: 191
Postby OP827 » Sat Nov 16, 2019 9:47 pm
This trailer is a another re-iteration of the folding walls trailer. Second home build from the same builder, Valentine.
New ideas here:
1. A new idea of gas struts being fixed with a flat extending bracket that allows simpler roof design and a better roof seal during transport mode. This appears as an improvement over UK factory made "Gobur caravan" similar trailer gas struts arrangement.
2. Trailer seems to be removable from the flat bed trailer.
OP827
Images: 379
Folding Panelized tent shed
Postby WizardOfOdds » Sat Dec 07, 2019 10:47 pm
I was a bit lost in writing a title for this one, not sure if it should be called a shed, tent, shanty, or kool aid stand. Very clever folding, reminds me of the folding ice shanty designs I covered in earlier posts. I like the large roof overhangs and large windows (I would prefer transparent window doors). No info on weight or construction (in english anyway). Not sure how much of the center wall is required for stability, I would prefer one large room over 2 half sized ones. Also, I think they built the door to open inward in order to avoid the roof overhang slope. It might be a better trade to shorten the door height and have it open outward. In any case lots of ideas here to think about.
Update 12/9/2019
Well it seems this is a commercial product. See reply by BallaratDragon in the comments section of the You Tube page. He notes:
open 2.1m x 3.1m, closed 2.1m x 0.6m 100 KGm (220#)
See https://www.utiltermo.com.br/
They sell a 'Thermal Floor Tent' and a thermal trailer (photos show 2 different ones??)
Tent data from site:
open 2.5m x 4m x 2m ht
closed 2.5m x 0.6m x 2m ht
Trailer data: open 3m x 5m x 1.9m internal ht
closed 3.7 x 2.1 x 2.85m ext ht
Interestingly, these seem to be polyethylene (think pool noodles) covered with vinyl canvas. I started collecting LDPE packaging leftovers years ago, used it for a foam door. Did not like that: LDPE is not rigid, and the white variety passes a lot of light - headlights passed thru my 2 inch thick uncovered door! Thick sheets are made with layers about 1/2 inch thick, not sure how they bond them but if you could do it at home, it would make curved surfaces easy. Interesting stuff (not cheap), but details better saved for a separate post
WizardOfOdds
Images: 44
Flat Panel Tear Drop without the Tears
Postby WizardOfOdds » Sun Dec 29, 2019 10:36 am
Are you OK with crawling into a Tear Drop but not part of the Curve Cult? Then maybe the Polydrop offers some ideas worth consideration. No curved surfaces to deal with, and might be a good match to those flat foam panel ideas you have been toying with. So far the gallery is heavy on CAD and light on real pictures, but worth a look.
Details from https://www.trailerlife.com/rv-gear/rvs/tiny-trailer-polydrop-limited-edition/
2019 Polydrop Limited Edition
Exterior Length: 12’ 5”
Exterior Width: 5’ 6”
Exterior Height: 5’ 4”
Freshwater Cap.: N/A
Black-/Gray-Water Cap.: N/A
LP-Gas Cap.: N/A
UVW: 760 lbs.
Hitch Weight: 80 lbs.
Axle Weight: 1,200 lbs.
GVWR: 1,200 lbs.
MSRP, Base: $9,000
WizardOfOdds
Images: 44
Postby mallymal » Wed Jan 01, 2020 8:51 am
Loving the polydrop!
Look how the front wall gently slopes, so you get a comfy angle for sitting up in bed.
I would love to build something inspired by this!
mallymal
Images: 18
New video of 10 Unusual trailer
Postby WizardOfOdds » Wed Jan 15, 2020 9:47 pm
This recent video include ten trailers, including the PolyDrop (see recent post above).
Most interesing to me is the Earth Traveller, a 300 pound long tear drop made with a chicken feather composite. It has a pop up hatch-like roof with fabric sidewalls at both ends, and lateral expansion tents. Minimalist with lots of windows!
This video also some interesting views from overseas.
The Earth Traveller is also covered at the end of the 2nd video
https://youtu.be/RKSKs2tQqWs
WizardOfOdds
Images: 44
Self powered camp trailer
Postby alaska teardrop » Mon Jan 20, 2020 6:24 pm
alaska teardrop
Postby tony.latham » Thu Jan 23, 2020 2:22 pm
No doors or windows. Hmmmm...
It's obvious they are trying to market their camper mobility product and not a camper.
Postby alaska teardrop » Mon Feb 03, 2020 1:24 pm
Yes, but it may be part of the future.
Featherstone imagines: "Here's an Airstream vehicle, it's autonomous, it powers itself, you go to bed at night and you wake up and you're at Yosemite."
Link: https://www.cnet.com/roadshow/news/airs ... ure-plans/
8)
alaska teardrop
Postby aggie79 » Tue Feb 18, 2020 11:41 am
While camping this weekend, one of these Opus folding/inflatable pop-up tent campers pulled into the site next to ours:
https://www.opuscamper.us/off-road/
This was a brand new camper and the owners were setting it up for the first time. I was amazed at how quickly it set up. The camper had the optional annex/side tent. It too had the inflatable structure.
There was a pretty wind good blowing and it didn't seem to affect the camper.
Take care,
For more on our Silver Beatle teardrop:
Images: 676
Postby OP827 » Sun Apr 12, 2020 5:44 pm
Came across "Tipoon the travel machine" French video of a real trailer, not a 3D model. I could switch on subtitles and translate them to English.
The guy said they received a first batch of orders and renting a 1000m2 hangar and hiring people to start production. This is a pretty complicated build and I am not surprised to see a lot of metal panels and parts because it needs to work more like a rigid mechanism with very little distortions possible.
They mentioned 20-25k Euros ($27k+) as a price at the end. The video is from 2017.
OP827
Images: 379
VERY unusual build
Postby WizardOfOdds » Sat Jul 25, 2020 5:45 pm
WizardOfOdds
Images: 44
