john wrote:Concerning the drop floor you might want to throw into consideration an uneven road surface. Entering a gas station for example.
The dip for the roadside gutter combined with the hump of the gas station entrance can cut into your clearance.
From what I've been able to measure the bottom of the box is about level with the bottom of the axle. The line is worst case coming off the hitch with the jack all the way up. But you're right about some of those speed bump and gutter combos being a real pain in the undercarriage. I'm planning on framing it in with angle iron and may add a couple of skids from the front of the frame to the front edges of the box just for such places. This drop floor idea is gonna depend on what the frame looks like once I get it stripped and will most likely move toward the back a bit which should increase clearance.
Thanks for the input! I'll certainly keep it in mind.
