Shadow Catcher wrote:One thing you need to remember is that control wires are from what I understand DC and you will want to go with at least 10ga wire.
It doesn't matter if they carry ac or dc the current they carry is most important. Give that they are control wires, I'm sure that for the short distances we're talking about, if you match the existing gauge, that would be more than adequate.
Human body at rest little more than 300 btu per hour
http://www.engineeringtoolbox.com/met-m ... d_733.html
it takes 142 btu to melt a pound of ice.
http://en.wikipedia.org/wiki/Talk:British_thermal_unit
r value equals feet squared X temp difference in degree f X hour/ btu
http://en.wikipedia.org/wiki/R-value_(insulation)
Styrofoam is typically about r 4 per inch so lets assume our tear has 1 inch Styrofoam on all surfaces.
So heat loss/ gain is btu/hour=square feet X temperature difference in degree F/R value
typical tear 5 w X 4 high X 6 long equals
sides 4x6=24 x two sides = 48 square feet
ends 4x5= 20 x two sides = 40 square feet
top and bottom 5 x 6 = 30 square feet x top and bottom = 60 square feet
total= 148 square feet
If we want the inside temp of the tear to be 70 degrees and the outside temp is say 90 degrees heat loss/gain would be:
Btu/hour= 20 (temp diff in F) X 148 (surface area of teardrop sleeping compartment) = 296 btu/hour
So, under the best of circumstances we have 900 btu/ hour (two people sleeping in tear and the normal heat gain and not counting if the sun is shining or it is windy causing an increase in heat transfer).
So 8 hours X 900 btu/hour=7200 btu. 7200 btu/142btu/pound of ice=50 pound of ice required.
I think this is optimistic as there are many more factors that I can’t begin to calculate.
So, probably 75 pounds of ice will allow you to get a good nights sleep if the temp difference between the inside of the tear and outside is 20 degrees f and your tear has 1â€
