jml79 wrote:I have done a lot of work on boats and a lot of research on aircraft construction. Simple extruded polystyrene (i think i spelled it right) insulation boards in the 1-2" range with some form of puncture resistant outer coating (light fibreglass layer or 1/8" luan door skin) would likely give you all of the structural rigidity you would need...
brian_bp wrote:jml79 wrote:I have done a lot of work on boats and a lot of research on aircraft construction. Simple extruded polystyrene (i think i spelled it right) insulation boards in the 1-2" range with some form of puncture resistant outer coating (light fibreglass layer or 1/8" luan door skin) would likely give you all of the structural rigidity you would need...
See ultra lightweight floating popup camper for a current example of this construction applied to a tiny travel trailer.
Yes, it is "extruded polystyrene".
