Well, mostly Weekender. Thanks, Mike, for the great concept, drawings, and 3D renderings!
Be patient with this, I will be limited by time, finances, and weather (can't work in 110+ degree heat in Arizona).
This is how I plan to start
My idea is to use the current thickness of 3/4 plywood (I think it is now 22/32" ). I will splice plywood together using techniques gleaned from the forums, with extra thanks to Greg M.
I plan to remove plywood and create a frame of what is left. This should insure a flat wall.
In the drawing, what looks like the trailer extending beyond the back is actually to represent a trailer hitch receiver extension, so I can mount my bicycle carrier on the back.
My first project, this weekend, will be to build 4 sawhorses, 5 ft wide, to support a work surface. I will have to tear this down after every use, as space is a premium.
I saw an awesome parking structure on one of the threads (sorry I cannot give credit, I couldn't find it again) that I could build and my HOA would never see it, so that may be in the plans as I make progress.
Note: Found the parking structure! Roly's 1/2 Nelson! Awesome! Such a creative lot you are! Take a look for yourself!
http://gages-56.com/roly9.html
Wish me luck!
Cliff
