converting ARE truck cap to camper
Postby kc2hje » Wed Mar 24, 2010 3:40 pm
have a chance to get this for a very low price FREE :)
thinking of just doing a simple trailer 5 x 8 with 2x4 studs and 1/4 inch plywood for the outside
total inside height would be 4 feet what do you think, ideas, suggestions, tips etc
told by the manufacture the cap is app 150 Lbs
kc2hje
Postby jagular7 » Fri Mar 26, 2010 2:47 pm
Sounds great....
Here another idea for that topper. Its not much in length, so to add room, make the side doors drop down and be supported by an inside cable system. Take the top and have it pop-up or crank up (if you can figure it out) or have it pump up to give you standing room. Tie the panels with the interior with cloth fabric. The drop side doors become your beds.
This makes a 'Bethany' slide-in camper.
Mike
Jagular
Lenexa, KS
jagular7
Postby Miriam C. » Mon Mar 29, 2010 9:09 pm
:thinking: It's late but I got lost. Are you going to put this on a trailer? Why do you need 2x4's?
Looks like a workable camper to meeee.
Postby kc2hje » Mon Apr 12, 2010 1:08 pm
was thinking due to the total height being 5 feet that to withstand 65Mph i would have to build the wood frame out of 2x4's can anyone point me to a lighter construction material for frame; skin; floor etc
Thank you for the help
kc2hje
Postby Ageless » Mon Apr 12, 2010 1:46 pm
Depends how deep yer pockets are. Most of the aluminum skinned trailers use 1X2, 1X3 for framing. High end ($$$) ones will use a welded aluminum frame. As for skin, you have a wide choice; aluminum, eposxy over plywood, fiberglass, etc
Ageless
Postby kc2hje » Sun Apr 18, 2010 9:14 am
GOT the trailer :D
Carry on 5 X 8 mesh floor with gate
weight is 400 Lbs
-40 for gate
-10-15 for mesh and other unused parts
= 350 ish for trailer weight
Has 6 inch sides went with that to add more structure to the camper for the corner jacks and provides good attachment point for tables and such without mounting right to the wall skin
total price for the trailer was 560.00 and just found out the gate is sized :twisted:
Pick it up next Saturday and start the work Monday night
kc2hje
Postby kc2hje » Mon Apr 26, 2010 12:29 pm
So the good nes is the trailer is at the shop having the corner jacks welded up :)
Bad news is I am in florada so no work (on the trailer) till Friday
kc2hje
