Tip Top Tier Drop
Tip Top Tier Drop weight measured
Postby WizardOfOdds » Mon Jul 18, 2016 8:25 pm
I finally got around to weighing the Tip Top Tier Drop (Pisa Ed) at the local landfill. The result: 550 lbs (+/- 10 lbs; the scale had a granularity of 20# and vacillated a little). This is just the empty trailer (includes tonge jack but no mattress or any equipment), and a little less than I anticipated. I expected the Pisa Edition to weight a few pounds less than the original, but it now looks like my original estimate was a bit heavy. (That estimate was made by adding up the volumes of various wood parts and applying an estimated density. It gave an estimate of 570# plus 30# allowance for metal hardware for a total of 600#.)
I am happy with the results because it falls within my desired envelope for towing with a 4 cylinder TV and I doubt I can bring the total down much without major concessions.
WizardOfOdds: Chalet shaped rag roof clam shell TIER drop for 4 cylinder tow
Tip Top Tier Drop thread http://www.tnttt.com/viewtopic.php?f=5&t=56232
Unusual Designs thread http://www.tnttt.com/viewtopic.php?f=5&t=64495
Tale of 2 Trailers thread http://www.tnttt.com/viewtopic.php?f=35&t=61451
WizardOfOdds
Images: 43
Re: Tip Top Tier Drop
Postby OP827 » Thu Aug 18, 2016 9:10 pm
Thanks for sharing. I really like the simplicity and yet great functionality of your design. I have read your thread in full now and noticed that back in 2014 you were looking for a free CAD program which can be used for modeling moving parts. I had the same need and found that in sketchup I could use move and copy tools in combination with layers to create copies of moving parts to view them in separate layers. I also had difficulties learning sketchup until I found (in my opinion) some very good tutorials to learn how to use sketchup here: http://jayscustomcreations.com/sketchup/
Using keyboard shortcuts saves me a lot of time and makes 3D modeling much quicker.
I wish you and yours all the best. Hope to see more of your creative thinking.
OP827
Images: 405
Postby WizardOfOdds » Fri Aug 19, 2016 9:22 pm
Thanks for the kind words and the tip on Sketchup. The reason I wanted a CAD that does moving parts is to help in dealing with an issure I call "lock down", a situation in which the trailer can be in either of two configurations (open or closed state) but can not move from one to the other because some parts limit movement before the other state can be reached. I call it lock down because I first encountered it with a design in which you could not lift the upper portion because as you lifted the back end, another part of the top needed to first rotate slightly downward (before reversing and raising upward). This is only a problem with multiple pivot designs. One fix was to accommodate the small downward movement with cutouts in the base, and I recall writing a program which displayed all the moving links for various degrees of opening. I also recall there was a freeware program for doing stick figure cartoon characters with multiple pivots which calculated and drew the new locations of connected links as you move one of the joints, but I never got around to investigating it much.
Right now I'm busy with other things, but I'll try to see if I can draw up a stick figure to illustrate the problem. I'll also give Sketchup a try after looking over your tutorial links. Thanks for the tip!
Edit 6/13/2018: I did put together an animated gif to illustrate this over a year ago, but it would not animate when uploaded to my album. The second try (months later) had the same problem. My 3rd try (tonight with a less complex gif as a test) suffered the same fate. I plan to add it here as soon as I can resolve why the post does not animate.
WizardOfOdds
Images: 43
Clam Shell Comments
Postby WizardOfOdds » Sat Jun 09, 2018 10:57 pm
I just added the comments below to a thread in the "Foamie" forum. I am adding a copy here because it relates to the overall history behind the Tip Top Tier Drop...
As this will essential be two open “halves”, only attached by a piano hinge at the back and lock down clamps at the front (when traveling); will foam give enough rigidity to keep it from flexing, or do you think I’d need a stick frame (say 2x2) with XPS?
For what it’s worth, here are my two cents:
I don’t worry about the closed state, nor do I consider the key question to be rigidity of the erected configuration (top raised and latched)....
Yes, it is true that a opened pop up does not have the rigidity of the classic tear drop or even that of a simple fixed box trailer, even though the two halves are latched together. This is especially true with a telescoping top because (unlike the base), the top can not have cross corner reinforcement (it has to nest over the bottom). However, my chief concern in designing the Tip Top Tier Drop was always the stability of the top during erection before it is latched to the bottom. Diagonal flexing was my major worry because the top had to be manually raised (by an elderly weakling with no assistance) and that meant holding it in the raised position with one hand while latching with the other. Finding the right balance between stability (rigidity), cost and weight was my aim and that drove me to experimenting with very marginal construction to see what I could achieve.
Manual lifting also put a limit on open height since I had to be able to reach a height clearing the latches. I knew this would be problem with camp sites that “rolled off” in the back, but what I under estimated was how often that would be the case. In fact, many camp site pads have a log back stop (which often ends up under the rear of the trailer) and a steep drop-off beyond it, creating quite a step down off the back of the trailer. We keep a stool handy for such situations, but sometimes that stool is needed just to raise the top.
Your diagrams show the reverse, the top is hinged at the rear, which has an obvious advantage in such a case. Also, your flip-up end and side walls should reduce lift weight, but there are set up exposure advantages with telescoping designs. In any case, I find clam shell designs well matched to manual erection constraints.
WizardOfOdds
Images: 43
more Clamshell comments
Postby WizardOfOdds » Thu Sep 06, 2018 9:34 pm
I just added some comments to this thread
viewtopic.php?f=55&t=70852&p=1236702#p1236702
which compares clamshell and four panel pop-up box designs. I thought it appropriate to add my comments here for readers of the Tip Top Tier Drop Thread. Postal Dave says:
“I just hope that when It's set up at the beach, or somewhere like that, it isn't so light that it gets blown over.”
Along the same line, is keeping the top under control. With a clam shell, one end of the top (front end for mine) is securely anchored at all times. Although I have latches to keep the roof in place while camping or driving, during erection and folding I need to control the loose (rear) end. One worry I have, which may be of limited concern to younger/stronger/taller builders, is this: Any top light enough for me to raise (and hold up with one hand while raising the end panel with the other) is light enough to be a problem with wind gusts.
From my perspective, the box trailer is less stable and less resistant to wind/rain during erection and folding, in part because there are just more steps that take longer to complete. Since 2011, I never had even a scare..... until this year when a very sudden storm hit while I was preparing to depart an open site over looking a large lake. I got things closed OK but I was concerned that the gusts might overpower me.
Is it unreasonable to fear that wet folded panels might drip dry onto bedding? My Tip Top Tier Drop has one folding panel (in the rear) which comes close to overhanging the bed (unless I fold the bed forward) but I have had no drip dry problems so far. Along the same concern, I try to avoid any roof seams/joints/hinges over the bed to avoid leak problems.
WizardOfOdds
Images: 43
Re: more Clamshell comments
Postby S. Heisley » Fri Sep 07, 2018 7:33 pm
WizardOfOdds wrote:I just added some comments to this thread
In the 7 years that I have been camping in mine, (knock on wood) all has done very well. I have some props that I can use to assist me in set-up but I don't find that I really need them, such as what I call "worry straps" that hook from the roof to the chassis when I am putting it up or taking it down in the wind. My roof weighs 70 lbs; but, like yours, it is hinged on one end. Lifting just one end changes the lift weight to just 35 lbs. If I know a storm is coming and I am planning on leaving that day, I usually take it down early. I can still get inside an do whatever I need with the roof down; but, it makes it what we call a "slouchy". I've only once had the folding sides so wet that I slipped a bath towel in between the folding sides, just to be on the safe side. I think you've got more worry from people who don't watch where they're going while they are driving. (Sorry for your loss a few years back; but, you came back and probably better than ever!)
Postby S. Heisley » Fri Sep 07, 2018 7:39 pm
In the 7 years that I have been camping in mine, (knock on wood) all has done very well. I have some props that I can use to assist me in set-up but I don't find that I really need them, such as what I call "worry straps" that hook from the roof to the chassis when I am putting it up or taking it down in the wind. My roof weighs 70 lbs; but, like yours, it is hinged on one end. Lifting just one end changes the lift weight to just 35 lbs. If I know a storm is coming and I am planning on leaving that day, I usually take it down early. I can still get inside and do whatever I need with the roof down; but, it makes it what we call a "slouchy". I've only once had the folding sides so wet that I slipped a bath towel in between the folding sides, just to be on the safe side. I think you've got more worry from people who don't watch where they're going while they are driving. (Sorry for your loss a few years back; but, you came back and probably better than ever! It says a lot that you built the same thing again.)
Postby gcsherwood » Mon Dec 17, 2018 12:40 pm
I'm thinking about building a foamie very much like the TTTD. Raising and lowering the lid looked like a problem, especially trying to do that while putting in supports and whatnot. I came across this solution -- 12V linear actuators. Amazon carries them for around $200 a pair depending on length from WindyNation. They are kind of slow at .4 in/sec, but that is still less than one min up to down (and vice versa) for all but the longest one (30 in). Placed reasonably close to the hinge you don't need all that much travel and they can lift 225 lbs each -- a pair of them, one on each side for balance -- would be far more than sufficient and they stay locked wherever they are when power is removed. I'm not a salesman for them -- really! -- but they sound almost ideal. Has anyone considered these, or am I missing something obvious?
https://www.amazon.com/dp/B07957YCM1/re ... ail_3?th=1
geoff
gcsherwood
Postby gcsherwood » Fri Dec 21, 2018 7:05 am
After poking around more I found the fly in the ointment. Other threads on this site pointed it out as well -- if you use multiple actuators you have to ensure they work at the same rate. They push with 225 lbs of force, so if they aren't in sync bad things could happen. And replies on the Amazon site from the manufacturer say that the speed of the actuator is load dependent. They say the load has to be evenly distributed to extend at the same rate, but I could see internal friction, wind, ground uneveness, etc, all contributing to an uneven load even if the weight were balanced. And if one were to fail, its lights out for the rig. Back to the drawing board....
gcsherwood
Postby Tomterrific » Fri Dec 21, 2018 9:05 am
I have a flat back lifting hatch that we keep up to stand under. It is a nice place to change clothes with curtains around it. I was worried about the hatch over lifting in wind and wanted a convenient way to lock it in the up position. I found broken pop-up canopies in the dumpster at many campgrounds. The locking two piece legs are perfect for this. Just cut to size, attach to top and floor, and the button locks the hatch strongly in position. I hope this gives an idea.
Tt
Tomterrific
Update - not much new
Postby WizardOfOdds » Mon Sep 23, 2019 11:03 pm
I'm not much for small talk, but I suppose it's time to update this thread even though there is not much to add. I had to replace some rotting wood, stuff I did not adequately paint in my frustration with the rebuild after the accident in 2014. And one of the original HF tires delaminated causing some damage. I finally learned to cover the trailer during storage to avoid sun damage - it's a lot easier to throw away a cover once a year then to resurface the roof. I like the vinyl on the lower tier sides so much, I covered the the front of the top with it. It wouldn't be hard to cover the rear panels, but I don't see an easy path to adding vinyl to the sides of the top because of it's external frame.
The Pisa edition was intended only to provide camping while building the next trailer, and pondering what to build next has been a never ending dilemma. Bypass surgery put me out of action for over a year and, like the demise of the original trailer, caused me to question priorities. The current design meets our needs really well given that we tow with a 4 cylinder vehicle. Records show we spent a total of 128 nights in it over the years without any major complaints. Over the 5 longest trips (5K+ miles each) we averaged from 26.1 to 27.0 mpg. Correcting for miles driven without the trailer, we still get 26+ mpg while towing. So at this point I have no firm plan to build anything substantially different.
WizardOfOdds
Images: 43
