Yup, Buford was dead right. I'm still reading as fast as my little eyes will go and then there's still the 150 e-mails to go as well...
As designed the fenders were custom-made from plywood - this was intended as a basic design for people to whom the phrase 'store-bought' might cause offence...
The way the hatch hangs out over the prop is indeed a possible weakness - if you want a hatch that can be swung on (that would be by the beerholder, I guess?) then a separate prop further along is needed.
On the Simple, the prop acts on a corner brace that joins the 'top' and 'back' of the hatch, so that is a stronger joint than it may look. The 'top' bit of the hatch is pretty vital as otherwise the hatch will be a head-bumper when it's open. For the Rimple, I had assumed the hatch ribs would be made from at least two layers of 3/8" ply laminated together.
Mike's comments about overloading the interior with too much storage sound right, so I guess that's a design mod to add to the list of things to do...
And I second Rik's comment about adding some fiberglass tape where additional strength would be a benefit.
Must stop reading and eat.
Andrew
