Traditional Galley Hatch on Square Teardrop
Postby kirtky97 » Sat Sep 24, 2022 4:54 pm
Howdy,
I'm looking at building a squared-off teardrop per the design below, which I found in the archived design library here on the forum. This, and almost all the other squared off campers I've seen, have a combination of galley hatch for the top and traditional doors at the bottom (with the exception of the Desert Dawg).
My question is, what is preventing a traditional, full-height galley door on a squared-off teardrop?
Thanks!
Kristian
Screen Shot 2022-09-24 at 3.43.02 PM.png (485.68 KiB) Viewed 1173 times
kirtky97
Re: Traditional Galley Hatch on Square Teardrop
Postby kirtky97 » Sat Sep 24, 2022 5:23 pm
Update: I finally found a camper with the hatch (and exact side profile) I'm looking for: https://www.vorsheershop.com/xoc
Any ideas on how complicated building a trailer with this profile and galley hatch will be compared to a traditional teardrop?
kirtky97
Postby tony.latham » Sat Sep 24, 2022 6:50 pm
kirtky97 wrote:Update: I finally found a camper with the hatch (and exact side profile) I'm looking for: https://www.vorsheershop.com/xoc
You'll note that the one you cited has tight radiuses instead of angles. The problem I see with building that design is skinning those tight curves. And an angled --two flat hatch with your sketch will be tough in my opinion. I think the joint angle is going to want to flex.
A curved hatch is easy... but that tight of a radius won't be.
:frightened:
Postby twisted lines » Sat Sep 24, 2022 8:43 pm
May look here great ideas & build video's With a nice shape :thinking:
oregontrailer.
Racking up; And Rapin foam
twisted lines
Postby Pmullen503 » Sat Sep 24, 2022 8:50 pm
Use baltic birch or marine ply for the ribs and and an extra rib or two. Epoxy and bias tape the joint; it won't move.
Pmullen503
Images: 67
Postby kirtky97 » Sun Sep 25, 2022 3:27 pm
:frightened:
Thanks for the feedback Tony! While I do like the look of the "cornered" design as opposed to a bigger, more traditional curve, I'm enough of a beginner that I'm happy to stick with whatever is easiest. Before I saw your comment I messed around in Sketchup and came up with my initial design (check it out here), it would be a bummer to scrap all that... any suggestions on how to approach the rear hatch so the curve isn't so tight? Could I build beyond the back of the trailer by a bit so the downward angle isn't so dramatic?
PS, just bought your book, looking forward to reading it!
Thanks,
Kristian
kirtky97
Postby tony.latham » Sun Sep 25, 2022 6:16 pm
Thanks. Don't be bashful with the questions.
Perhaps someone on here can help you figure out how to manufacture an angled hatch. I think it's problematic. But it's probably been done.
You have done a lot of work in Sketchup and it does look good. Perhaps you've seen Dan Lott's Sketchup series?
Don't be afraid of curves... :thinking:
Postby kirtky97 » Sun Sep 25, 2022 7:22 pm
I appreciate it! Any idea how much more complicated would it be to install a star-gazer window in a traditional design like yours vs a squared-off front like my idea? Considering I'd like to have roof bars and/or a solar panel as well...
kirtky97
Postby tony.latham » Sun Sep 25, 2022 7:23 pm
kirtky97 wrote:I appreciate it! Any idea how much more complicated would it be to install a star-gazer window in a traditional design like yours vs a squared-off front like my idea?
It isn't any more complicated. I think Frank over at Vintage Technologies has got the leak problems fixed with his moonwindow.
