Attic build - Twin Bed Micro Teardrop
Re: Attic build - Twin Bed Micro Teardrop
Postby atticdrop » Mon Feb 27, 2017 1:26 am
It got stupid cold and my attic doesn't have heat. But I got some things done recently. I also got my hitch on the Mazda and a transmission cooler installed. Here's a pic of us ice racing.
atticdrop
Postby atticdrop » Sat Mar 04, 2017 6:31 pm
I finally picked up my galley hinge from TC Teardrops in Wisconsin. The price was reasonable and I like the rain gutter featured in their construction.
I also picked up 4 sheets of marine grade plywood (1/4 inch sides and 5/32 inch roof) and a little bit more cherry for my cabinet doors. I go to Kettle Moraine Hardwoods in Adell, WI. They have great Baltic Birch 5x5. I also used Alpine Plywood for my Baltic birch floor. They had 4x8.
Wheels are on the way from Wheels Vintiques. 15x5 Chevy style rims. These will match my 85 suburban. Tires will be Yokohama Geolander at/s in 205/70r15. These have 26.5 diameter with a 6.4 tread width, so I am planning 28x8 fenders. I like full fenders.
Last, I ordered a Dexter Torsion axle from Hanna Trailer and RV in Milwaukee. I ordered with a 45 degree down configuration for max ground clearance. They are local and I've worked with them before. Great company. I also found some online quotes, but Hanna's price was much lower anyway.
atticdrop
Postby atticdrop » Mon Mar 06, 2017 11:33 pm
More work on the teardrop today.
I took the whole thing apart and sealed the bottom with "the mix". Simply one part polyurethane and 1 part mineral spirits. I plan on using window flashing to cover the bottom as well.
I also got the inner cabinet frame done and rough cut the side sheathing. I bought marine grade plywood and it is almost too pretty to cover up. :(
Last, I started work on the galley door. I'm building it in place per many forum members recommendations. I will run spars between the supports and it will all be framed in cherry. It is going really well.
atticdrop
Postby atticdrop » Tue Mar 07, 2017 10:05 am
Wheels arrived today!Image
atticdrop
Postby atticdrop » Thu Jun 29, 2017 10:28 pm
My dog died in December and it's been hard to find the motivation to work on my project lately. Got a little more done.
atticdrop
Postby Job » Fri Jun 30, 2017 3:13 pm
AtticDrop, sorry to hear about your dog. I know how you feel as I have lost a dog, that was a cherished member of our family. My current dog Dub is like my best friend. Good job on your mini tear. It will come together in it's own time. I built a very similar camper this spring and just sold it 2 weeks ago.
Good luck with your build. Jeff
Job
Postby Pete Mc » Tue Sep 19, 2017 8:29 pm
Been away for a long while. So sorry to hear about Luca. Its hard to lose such a close friend. Hope you can find the strength and motivation to finish your project.
Sent from my Nexus 6P using Tapatalk
Pete Mc
Postby atticdrop » Thu Sep 21, 2017 11:22 pm
Thanks everyone. Luca was with me when I was working on this and am still working on it. Helps me relax and think about him.
Recently finished the interior wiring, battery compartment, and picked up my steel for the trailer frame. I'm using 2 inch square tubing (overkill is underrated).
atticdrop
Postby KCStudly » Fri Sep 22, 2017 4:04 pm
Nice. :thumbsup:
Postby jdiebert » Fri Sep 22, 2017 11:36 pm
Looks great! Great inspiration to get started on my own build
Sent from my Pixel XL using Tapatalk
jdiebert
Postby GVTrailer » Sat Sep 23, 2017 11:41 am
Great design and excellent execution. :thumbsup:
GVTrailer
Postby atticdrop » Sun Sep 24, 2017 11:21 pm
I finally welded up the trailer base. It's about $100 worth of steel from Speedy Metals. 2x2 .083 wall for the frame and .12 wall for the tongue. I couldn't figure out why my MIG was running like crap at the end. I was out of argon. Dope.
atticdrop
Postby KCStudly » Fri Sep 29, 2017 11:12 am
Grinding porous welds out really sucks, but you have to do it. :cry:
Might have been a good idea to have used the heavier wall tubing for the front xmbr as well (hope you did?).
Postby atticdrop » Sat Sep 30, 2017 7:25 pm
KCStudly wrote:Might have been a good idea to have used the heavier wall tubing for the front xmbr as well (hope you did?).
I did! Forgot to mention that.
atticdrop
Postby KCStudly » Mon Oct 02, 2017 6:18 am
