DaddyJeep wrote:I am new here and just starting out with the idea of building a camper. I have had plans for a couple years now to mount a pop up camper on the front of a car trailer so I can tow my Jeep and my camper at the same time. Thanks to all of the cool builds on here I have decided to take that thought to the next level and build a hard sided camper using parts scavenged from my pop up. I have been working on my design to maximize the space I have available on my trailer and have been doing a bunch of research on here to be sure I have a solid build plan. The construction will be a modified foamie of sorts. I plane on ripping the 2" foam into 24" or less widths and laminating the ends with 3/4" plywood for a little bit of strength. The drawing that I will attempt to attach will show the basic layout of things as well as where the plywood will end up. In addition to the 3/4" plywood I will be using 1/2" plywood on the top and bottom of the panels. I stretched my trailer almost 7 feet over the weekend, but I probably will not make too much progress on the camper until after the holidays. I encourage any feedback or questions on my build since there are a lot of knowledgeable guys here.
Goin to need some pics of the Jeep before I can condone this type of activity sir!
pchast wrote:Why so heavy?
If the trailer base was originally a mobile home frame, I'm hoping you ditched the axles/wheels for better equipment. Can't tell in the photo.DaddyJeep wrote:pchast wrote:Why so heavy?
The trailor was originally built out of a mobile home frame. It is not as heavy as it looks. The "I" beams are pretty thin, less than 1/8". I am continuing what was already done.
working on it wrote:If the trailer base was originally a mobile home frame, I'm hoping you ditched the axles/wheels for better equipment. Can't tell in the photo.DaddyJeep wrote:pchast wrote:Why so heavy?
KCStudly wrote:You don't need 3/4 or even 1/2 inch thk splice ribs. The thickness of the plywood dosen't add any strength to speak of in that direction, it is the thickness of the wall, the "width" of the plywood splice pieces that determines how good they will be at adding stiffness (flatness) to the wall panel. Sure a 5mm (3/16 thk) slat of plywood is pretty floppy when you wave it around by itself in free air, but when you constrain it between to pieces of foam that prevent it from bending in the y-axis (thin way) and only apply side load on the wall in the x-axis (wind, a tree branch or somebody standing a ladder up against it), then that 2 inch width of ply acts the same as a 2 inch stick of lumber, stiff as a board.
Truth, you don't even need the slats at all. Leave the foam in larger sheets so that there are a lot less butt joints to cut, align, clamp, glue, scrape, sand, and repair after you sand into the foam too far (the foam sands so much easier than the wood, or even the glue, that it is very difficult not to over sand the foam). All the advice I was looking for. I would never not see the wood in the finished walls because of the sanding difference you mention.
Make sure you leave a fair amount of depth in the header over your rear door, as that will be your only "shear" panel there. I would look for at least 4 inches, 6 would be better. I had not considered that If you don't want the roof that high you could use a "slouchie" height door. The roof height is constrained by the door in my shop, I would love to go a couple inches higher, but it just won't fit. You can also help gusset the wall to roof joint by building over head cabinets in along your side wall seating/bedding/kitchenette areas. The green on my drawings represent cabinets. The kitchen, on the same wall as the bathroom, will have a base cabinet and overhead cabinet. In the corner by the door it will be a full height cabinet. Along the front wall there will be thin cabinet that will add strength for the fold out bed. This will probably be framed in with 6 or 8" plywood. The base to the couch will probably tie everything together as well.
I'm not sure I understand your section diagrams. What is 4 inches thk? I'm very pleased with how rigid my walls are with 1-1/2 inch thk foam and 5 mm interior ply skins (even before adding the outside skin). i would think that 4 inches of foam would be excessive, unless you plan to do a whole bunch of sub-zero camping. If you are worried about the width and height of your front wall and being able to withstand wind pressure during travel, you could use a standard thickness wall and consider stepping up to a thin ply veneer, or just add a couple of foam ribs, like pilasters, covered with PMF. The 4" piece was supposed to cap the end of the side wall and tie it into the front wall. Since none of the wood is necessary anyway, it doesn't natter much. All of the foam will be 2"
The YJ looks like fun. Are you going LS or old school SBC?Somewhere in between...old school SBC with TBI. It is a mid 90's truck motor.
Thanks for the reply
Users browsing this forum: No registered users and 31 guests
