We plan to have an air conditioner in the front, so we wanted to epoxy both that compartment and the galley.
T
KTM_Guy wrote:Looks about right? Adding a few more coats will smooth is out without sanding. Or you can sand in-between coats to get it to smooth out quicker. Like Tony said I like to use a squeegee. I used some cheap plastic ones I found at Home Depot It is an edger for painting. Let the epoxy cure and it just peeled off.
Some of the problem may be with the fir plywood. The summer growth is very soft compared to winter growth which is hard. And the softer wood will soak up the coating more than the harder wood. Same thing when sanding fir. It's hard to get a smooth flat finish.
I use West System and would recoat when the first coat is about as sticky as masking tape.
Todd
KCStudly wrote:I've never been a fan of foam rollers or brushes. I use a squeegee where possible, and cheap chip brush (often times with the bristles cut down by 1/3 to 1/2) where the squeegee won't work.
It does look and sound like wood lint, but there may be other factors.
Did you keep your batch sizes small and/or pour them into a wide tray to prevent it from kicking off too soon?
Did it start to tack before you finished rolling? This can induce air or pull fibers out of the roller/brush.
Did you go over it a bunch of times (potentially inducing air bubbles), or just enough to lay down an even coat?
What was the climate like when you laid it down? If it was humid or going from cooler to hotter that can affect the finish. They say if you can catch it going from warmer to cooler and dry, those are the best conditions.
Keep with it. You will get there!
KCStudly wrote:I wonder if the pigment would perform much differently when saturating glass weave. Think about it, the wet epoxy makes the the glass disappear... maybe the pigment makes the glass appear and help it be more 'opaquer'. Just a thought.
If anyone has other suggestions for durable floor paint, over epoxy, we'd love to hear them.
tony.latham wrote:If anyone has other suggestions for durable floor paint, over epoxy, we'd love to hear them.
For the top of the floor? When would it be exposed? Are you planning on some kind of futon mattress so you can fold it up and sit?
Hi Tony,
The only part that will be regularly exposed is the back of the galley. We could leave it as is and just varnish for UV protection, but paint appeals to us more than the multi-footballed AC face back there.
Long as we're doing that, we thought we'd do the cabin too, just in case we do someday use a fold up mattress.
Also, we haven't completely made up our minds on the outer covering for the walls and ceiling yet, and if we find a paint we like, we might consider it for there too.
Users browsing this forum: No registered users and 51 guests
