Can I ask how much the ACM panels were? Are using 4 by 8 or a different size?
Thanks
aggie79 wrote:I'm really interested in your use of ACM and hope you don't mind a few more questions about your installation. You said that the ACM is attached to the framing by adhesive. Did you sand the paint away or do any surface prep to the ACM before applying the adhesive? Did you use any type of spacer to maintain a certain adhesive thickness or did you just apply the bead and "squish" the adhesive to whatever thickness resulted?
By the way, I love your design and you have mad fabrication skills!
