by Danomite » Mon May 06, 2019 11:49 pm
Over the weekend I got the insulation cut and stuffed into place. I also worked for several hours drilling & riveting all of the fill-in places. I had mainly just riveted the edges of the sheets when I put it on, but had not riveted every 6 to 8 inches on all of the crossmembers. I still have another couple hours to go on that, and then it's on to installing the 5/16" cedar tongue & groove.
BTW, the floor is 3/4 treated plywood. The reason I went with 3/4" is because I already had it. It was the sideboards on an old flatbed dump truck I bought to haul dirt, hay, and logs around the farm. The previous owner used it for hauling/holding grain, but sides are not of use to me on that truck. I coated the crossmembers with tar where they would contact the treated wood. After the interior is installed and polyurethane is applied, then I will install the vinyl flooring.
- Attachments
- Screenshot_20190507-010324~2.png (319.95 KiB) Viewed 3140 times
