1967 Kustom Koach rebuild
Postby pt kustom koach » Thu May 27, 2021 9:36 pm
So I finally sat down and made an album with a few pictures of the 1967 Kustom Koach build. It is 13 ft. from hitch to bumper and the cabin is 6 ft. 3 in. wide and 9 ft. 6 in. long. I think a few of the teardrops and foamies on this forum are bigger!
165624 Lots of rot! :( I ended up taking it down to the bare frame and was only able to salvage about 60% of the wall framing. All new roof rafters and interior plywood.
165625Scary hitch welds! :shock:
165626Poor attempt at frame repairs. :shock:
165627Front of the frame replaced and a new hitch welded on and longer fish plates inside and outside at the frame bend.
165628Frame repaired and painted> :)
165629Floor is on and all axle U bolts, bushings and bearings replaced.
165630Walls are going up.
165631Roof is going on.
165632Roof and walls up and 4 coats of semi-gloss varnish. Walls are 1/8 poplar veneer flooring underlay. $15.00 a sheet at my local big orange store! :D
165633Kitchen cabinet under construction.
165634Upper kitchen cabinet
165635Cooler cabinet and corner of front bunk support.
165636Kitchen cabinet with counter top and sink. Cedar face frames and door and drawer fronts. Pocket screws and glue holding it all together. 100 llb. full extension drawer slides. :)
pt kustom koach
Images: 14
Re: 1967 Kustom Koach rebuild
Postby Greg M » Sat May 29, 2021 6:10 pm
Looks great! Keep those pics coming :thumbsup:
Greg M
*Geek Extraordinaire
Images: 85
