Re: fast, cheap, fiberglass/ foam stressed skin panels
Postby tony.latham » Mon Feb 07, 2022 11:21 am
The exception to moving away is the death adder, he'll stay put.
At least our venomous crawlers generally give an audible warning with their rattles. Sometimes we call 'em buzz worms here.
:frightened:
Me? I've been known to jump 2' to 3' when a cicada cranks up his mating call right next to me. There's probably a reason they evolved to sound something like a rattler.
I think they are a good thing to have here. They help keep the wild in the wild west, just a little bit. Some wildness to keep looking for. :frightened:
Postby MickinOz » Mon Feb 07, 2022 9:14 pm
tony.latham wrote:I think they are a good thing to have here. They help keep the wild in the wild west, just a little bit. Some wildness to keep looking for. :frightened:
I'm with you mate. In fact it disturbs me that I seem to see less of them. There is a beachside settlement here that is on a sort of island (its only an island at high tide, and then only if you don't count the causeway). It was known for death adders when I was a kid.
The bloke I mentioned who had the adder bite that went right through his hand and dripped on the floor was the local snake expert.
He told me that the adders are now extinct on the island due to human settlement and encroachment.
Admittedly most of the snakes I mentioned were never seen in suburbia even back when I was a kid, but now they seem to be getting harder to find even in the bush.
MickinOz
Postby John61CT » Mon Feb 07, 2022 9:33 pm
Well the fact most bird & bug populations have been decimated compared to just 50 years ago
everything is connected, we have forgotten now maybe too late...
John61CT
Postby saywhatthat » Mon Feb 07, 2022 10:37 pm
As a kid we moved around a lot mostly the Middle East but the scariest snake that I've ever seen is when we lived in Vietnam the Malayan krait scarier than the cobras
they're called two-step Viper but mostly you die the Heart attack when you realize you steep near one.
Il suffit de le faire
viewtopic.php?f=50&t=73945
saywhatthat
Images: 135
Postby saywhatthat » Wed Mar 23, 2022 1:27 am
DIY fiberglass structural panels adding texture walnut shell imbedded with polyester resin
small .jpg (41.22 KiB) Viewed 370 times
IMG_20220110_163942 s.jpg (42.23 KiB) Viewed 370 times
saywhatthat
Images: 135
Postby saywhatthat » Wed Mar 23, 2022 8:13 am
for a bit of a different look . and act like a bed liner a hardened surface to protect the fiberglass easier to fix any gouges
saywhatthat
Images: 135
Postby saywhatthat » Fri Apr 01, 2022 12:45 am
sorry for going so slow with this trailer it doesn't match other trailer so I'm either going to shove it in the back or trade it off for something. Also have an extra hundred eighty feet of 5 x 10 by one inch panels 18 ea 5x10 by1in
Sadly there is less than 10 hours to finish the pod.
add a rub rail along the bottom that way if there's any damage easy to fix remember this trailer can last hundreds of years. I don't know why more people don't do this.
in staled door jam
and brackets for interior shelving in the back
Will be making cot / shelf with netting on inside pod
I know I've gone a bit Wild on the rivets but he'll for $19 a thousand all by hand too lazy to go to the shop and get a air Riveter
saywhatthat
Images: 135
Postby saywhatthat » Fri Jul 29, 2022 12:01 am
sorry about up dates . Cant use trailer because back dose not look like others.
I decided to work on my about $50 door free form no mold. I see what other people are charging is basically right at $400 for doors wacko
made a skin, added a eager for looks will add willey window . We use glass cut board for glass it tempered. when glue up will add foam round edge will add inserts for the door hinges and door handle lay up glass.
Need to make recessed door hinges I don't like the door to fit flush . I like it back little way makes it harder for animals to grab
thumbnail (1).jpg (209.18 KiB) Viewed 231 times
thumbnail (2).jpg (30.86 KiB) Viewed 231 times
thumbnail (3).jpg (31.46 KiB) Viewed 231 times
saywhatthat
Images: 135
Postby saywhatthat » Fri Jul 29, 2022 12:05 am
]this is what look like in my mind.
saywhatthat
Images: 135
