Simple_Abound wrote:Good luck with your build. If you haven't planned on it yet, I would consider welded tabs on the corners and cross braces to bolt the floor to the frame.
italianub wrote:Yeah they're welded on there already, however I put them about 4 inches from the corners and cross braces. I'm not entirely sure why I did it that way but it seemed better as far as spacing when bolting the floor when I was looking at it.
tony.latham wrote:Sweeeeet welds!
Pmullen503 wrote:Good looking welds!
jaimefg17 wrote:Which gauge did you use for the square tubes?
tony.latham wrote:What's the function of the tiny cross member near the rear of the tongue?
tony.latham wrote:By the way, I much prefer the weld-on swivel jacks.
Users browsing this forum: Bing [Bot] and 10 guests
