New build under way
New build under way
Postby Funluvin001 » Fri Oct 23, 2015 7:16 am
SO I started this out with inspiration from the foamie group, but after inheriting a job demolishing a 5th wheel, decided that I needed a full(ish) frame to re-use the fileon skin I planned to harvest. I picked a bad time of the year to start this Since when I started I was wearing shorts, and some 4 weeks later the weather has turned to single digits - centigrade, including a few sub-zero nights! Given the fibreglass work needed, it's been a struggle, but I'm making progress.
It will take me some time to build this thread, but I'll do the best I can. Thankfully I've shot a lot of pics along the way. The ultimate goal is to recycle as much of the salvaged material as possible
Here is the donor camper I agreed to strip:
136719
Here's why:
136720
Here's what the owner got back:
136721
Salvaged:
All exterior mouldings & vinyl inserts, windows, door frame & screen door, EDPM roof membrane, interior and exterior lighting fixtures, interior cabinets, propane furnace, filon skin, window valences,roof trusses, and misc hardware.
More to follow...
Funluvin001
Images: 145
Re: New build under way
Postby Funluvin001 » Fri Oct 23, 2015 7:29 am
Some harvested materials:
136722
136723
Now the build begins. I narrowed the frame to 82" for wind loading considerations.
136724
Floor framing:
136725
Skinned aluminium underneath with plastic to keep away from pressure treated 2X2 framing.
136726
Insulation & floor ply laid down:
136727
Minimal stick framing begins:
136728
More framing:
136734
Cut down roof trusses:
136736
Roof ply installed and insulated:
136737
Now for some foam in-fill:
136738
Spray foamed in place: (huge stability improvement here!
136739
On suggestion - frontal ply added:
136740
Nose skin alignment:
136741
Funluvin001
Images: 145
Postby Funluvin001 » Fri Oct 23, 2015 7:44 am
Sorry so condensed descriptions, but these were taken over the last month.
More build:
fibreglass repairs to skin: (almost a week's worth of repairs & seeming.)
136742
frontal skin epoxied on upper half:
136743
Skin seeming. upper pieces added because of the decision to use salvaged roof truss system.:
136744
Nose side-skins installed. Windows fitting:
136745
Gluing up side skin. PL premium on frame, PL foam adhesive on the foam. Neoprene gasket washer screws used to
some mechanical fastening as well.:
136746
One side skinned! (back is as well):
136747
other side skinned. The pin stripes alignment makes it look broken! LOL They'll all be sanded off and the whole trailer will get a nice coat of poly urethane paint.:
136748
Cleaning up the skin, and adding some trim pieces. Screen door and frame were salvaged but now I have to build a proper door to fit! Today's task possibly.:
136749
Fibre-glassed nose corners:
136750
Alas this is where we stand after a month. Spent last night scouring this forum looking for door ideas, but plan to use the same approach: XPS foal with a minimal framing.
I'm undecided what to final top the roof with. While I did salvage the EPDM membrane from the fifth wheel, it has many vent openings which I won't need and so while it may make a sort of second layer safeguard, it won't be my primary water proofing method. I'm debating fibreglass VS aluminium 4X8 sheets seemed, VS new EPDM, VS canvass & high bond primer/paint. TB2 is $40.00/gallon here - same price as polyester resin, so I will NOT be using that.
I'm sorta winging this build as I go, so I'm keen on any feedback/ideas/suggestions, etc.
Funluvin001
Images: 145
Postby Funluvin001 » Mon Oct 26, 2015 5:00 am
Since the parts donor owner had given away his door, I had to build one.
Here is the rough door:
136791
interior, not yet skinned.
136790
Trim to be harvested from:
136792
Temp installed:
136793
Those monstrous windows make this rig look tiny!
I'm still undecided what to do for a latch. I could harvest the one from the old door, and while I like the pocket mount, the thing weighs a ton, plus requires the installation of a dead-bolt as well. Always looking for ideas!
Funluvin001
Images: 145
Postby noseoil » Mon Oct 26, 2015 7:16 am
It's a giant foamie! Do you have an idea of the before & after weight for a comparison of the two methods? Lookin' good!
137905
noseoil
Images: 669
Postby Funluvin001 » Mon Oct 26, 2015 5:09 pm
Well the before would have been the fifth wheel and this is an entirely different frame from one I tried to patch up, and thanks to underestimating the contraction of the aluminium roof in winter, we towed home a giant bucket of mould. At the end of the day this chassis is entirely different from the fifth wheel, and it's probably going to weigh in with at least a %30 reduction over the old camper that was sitting on it.
Here's a sample of the framework that was 'repaired' with the old one:
136807
136806
And a couple of the finished before & afters.
Front:
136808
136809
Rear:
136810
136811
It really sucked to have to demolish all that work, but the amount of mould which grew in just a few months was incredible.
As they say.. live and learn!! :x
Funluvin001
Images: 145
Postby Funluvin001 » Mon Nov 02, 2015 8:10 pm
It's been a busy few days with some more fibreglass work at the seems, and finally decided to draft up a floor plan.
136996
Here is the meranti sub-floor laid down. Almost looks too good to cover over!
136997
Funluvin001
Images: 145
Postby Funluvin001 » Wed Nov 04, 2015 6:03 pm
So the last few days have involved installing exterior lighting and pre-wiring for interior panels.
137006
137007
137008
I burried as much of the wiring as possible into the foam, and then spray foamed in over top of it. Now I'll have to take care to avoid it when installing the interior panels.
Funluvin001
Images: 145
Postby dales133 » Wed Nov 04, 2015 6:14 pm
Nice!
Big project and its realy starting to shape up nicely
dales133
Postby Mr. Lahey » Wed Nov 04, 2015 6:30 pm
WoW!! :shock:
That looks great...and a huge project too!
New improved name for the board?
Tiny Travel Trailers plus a bigun too!
My teardrop camper build journal: http://www.tnttt.com/viewtopic.php?f=50&t=64721
Mr. Lahey
Postby Funluvin001 » Thu Nov 05, 2015 7:10 am
Mr. Lahey wrote:WoW!! :shock:
Well, it's 13 X 7 so not that big really... but it's certainly a large scale undertaking. The interior is only 6ft high too. Good thing we're not tall. LOL
Funluvin001
Images: 145
Postby rebapuck » Sat Nov 07, 2015 1:35 pm
All those windows will keep it nice and bright. And you're right, the windows do skew the size perception.
Judy
1966 VW camper
1967 VW singlecab
rebapuck
Postby Funluvin001 » Sun Nov 08, 2015 6:21 pm
So after some gruelling messing about with wiring, a bit more fibreglassing in a couple of forgotten areas, and using a top coat of epoxy & glass along all the roofing seems, we finished those segments and were able to get on with panelling the interior:
137169
And today we got the re-claimed overhead (kinda) cabinets installed!
137170
It's starting to resemble the end result. I scored a buncha cushions from another demolished camper we helped a friend out with a few years ago, so building the bedding is up next, but first I'd really like to get some flooring down, and perhaps finish up some interior trimming. It's starting to come together! Also have yet to skin the inside of the door and add a deadbolt to it. So many 'little details', so little time! :thinking:
Funluvin001
Images: 145
Postby Funluvin001 » Mon Nov 09, 2015 6:48 pm
So we decided for sure that we're painting the interior white to maximize the trim options at our disposal. There is still some thought being given to another colour but for the time it's while base, before all of the trimming and interior stuff goes in.
We had the bulk of a gallon od CIL primer paint combo left over from last year so used it. It took 3+ coats to get half decent coverage, and it still needs another. This paint is as poor in the coverage department as is Behr. Never again will I use either of those!!! At any rate here is another foreshadowing pic of things to come:
137178
Funluvin001
Images: 145
Postby Funluvin001 » Mon Nov 16, 2015 6:55 pm
So it's been a few days since I posted.. work's not stopped, it's just that there's been little visible to show for it all.
I did more fibreglass work on seems I hand't originally planned to, and so now they're ALL glassed. (all exterior seems)
Then I laid down another coat of paint, did some rough trimming, did some prep work to place the fridge and inverter.
Also had to plan for the insertion of a regulator for all the LED lighting, but the wiring was pre-planned with that in mind.
With over half of what will be finally installed turned on, it draws only half an Amp!! :D
I Took the old incandescent fixtures and reloaded & hard-wired them all with LED banks. Also started on some of the rough trimming.
I'm tying down as much as I can while awaiting the flooring. I Also skinned the wheel wells with Meranti/Luan, and plumbed in the propane
feeds for the furnace & cook top. After all this I also gutted an old UPS, and used to to make something of a power bar and automatic power feed toggle,
between AC mains and the inverter such that as soon as you plug in an AC feed the camper switches to it, from the inverter.
Though it will primarily be powering the fridge. I will be left with 3 outlets which will similarly auto-switch, and 3 which will only be active from AC mains.
I patched into one of the inverter's sockets which will directly feed into the switch box, but unfortunately forgot to snap a pic of that setup. :cry:
I'll be building on a storage box on the rear frame to hold the battery & propane tank, if anyone's wondering why I did things the way I did.
137382
137383
137384
137386
137387
137388
Some pics:
Funluvin001
Images: 145
