"Pork Chop Express"
Re: "Pork Chop Express"
Postby rebapuck » Sun Aug 03, 2014 12:18 am
Can you start the new job earlier?
Judy
1966 VW camper
1967 VW singlecab
rebapuck
Postby SLUG36 » Sun Aug 03, 2014 12:25 am
rebapuck wrote:Can you start the new job earlier?
I start Monday. no biggie. the wife has been working extra hours to help.
Making big pieces of wood into the wrong size..... for over 30 years....
SLUG36
Images: 137
Postby SLUG36 » Fri Aug 22, 2014 1:55 pm
123465
have no fear, I am still slowly working on my TTT. The South East Texas Summers are Brutal, and with a heat index today of 103, 45% humidity, and no air movement. I have slowed down working outside. last night I started with body filler over the street side lath's that make the roof to side wall radius. and ended up working on more filler this am till about noon. slowly working from the rear to the front. I am determined to keep some progress going on the build.
I have also made some progress on other areas of the build, but, nothing to wright home about.
I just wanted to let everyone know that the build is not stagnate and progress is going slow because of the summer heat. and helping my parents finish some stuff on their house.
SLUG36
Images: 137
Postby SLUG36 » Thu Sep 04, 2014 11:36 pm
Determined to keep this build going. I made a fixture from some Red Oak 4x4 for the 3~$1 cheap LED flashlights. I just need to wire her up again and find a good location for my wife to have a reading light.
123935123934
SLUG36
Images: 137
Postby rebapuck » Fri Sep 05, 2014 10:08 pm
Very cool.
Judy
1966 VW camper
1967 VW singlecab
rebapuck
Postby SLUG36 » Sat Sep 06, 2014 8:08 pm
here is a link to a post I did testing the cheap $3.00 light.
http://www.tnttt.com/viewtopic.php?f=30&t=59167
SLUG36
Images: 137
Postby SLUG36 » Sat Sep 13, 2014 10:30 pm
I finally finished doing something with the LED light setup. I decided to make a reading light for my wife. the arm is from my drill press that the LED light burned out on 5 minutes after setting up the Drill Press. it has been in my way for over 4 years.
124310
SLUG36
Images: 137
Postby SLUG36 » Sun Sep 14, 2014 7:01 pm
I spent today hand cutting the perfect pattern to cut the holes for the computer fans in the 3/16" aluminum plate. but, unfortunately the hard board I was using for the router template didn't work out too good for the router to follow.
I had cut out for 3 computer fans. but, the 3rd wasn't moving that much air. so it was left out. the wood frame around the fans will have a foam seal so the fans only draw in fresh air and not recirculate the hot air.
124322
the fans are tied into the same 12v circuit that runs the control panel for the 2 way fridge.
SLUG36
Images: 137
Postby SLUG36 » Wed Oct 01, 2014 7:47 pm
after putting it off for over a month, I decided to make the trim for the sides of the cabinet that houses the fridge. 8 pieces of 1 1/2"x 3/4" #1 pine with a 3/8" x 11/16" rabbit milled.
124895
I have the wood cut for the other side, but I dont have the 1/8" oak ply installed yet. and you can also see I installed another LED light in the ceiling above the shelf on top of the fridge.
SLUG36
Images: 137
Postby Atomic77 » Sat Jan 24, 2015 11:13 am
This is going to be an awesome build. How's things going? Any recent progress?
Michael
"The Strength is in the Sum of the Parts..."
The Astroliner
Follow The Astroliner Blog Here!
Check out our YouTube video
Atomic77
Images: 309
Postby SLUG36 » Sat Jan 31, 2015 11:33 am
No real progress lately. Have be without work for a few months. But i am looking forward to getting back to work on it. And thanks for the compliment.
SLUG36
Images: 137
Postby dodgedartgt » Thu Jul 25, 2019 11:13 pm
Old thread here,left unfinished. Whatever happened to this. I hope you found work.
Mike in OR
dodgedartgt
