Metalhead wrote:Your build looks great!
I love how you did your AC and have been debating how to do the same on my build. I thought about doing a slide-in/out style but the way you incorporated yours into your tongue box is very impressive. Hope you don't mind if I borrow some of your ideas .
Gunguy05 wrote:Can't wait to see that aluminum. We are most likely ordering from SAF as well, as we need 5 ft pieces and the free shipping looks good too. I'm guessing you went with .040 mill finish?
Looking great, and getting closer! Keep up the great work.
Gunguy05 wrote:Looks great. I think you will be flying through it from here on out!
rebapuck wrote:Another milestone is always good.
chriskoebb wrote:Great looking work! Super craftmanship
Did you leave the axel on top of the leaf springs as in the early photo's?
tony.latham wrote:You're quite the fabricator with the aluminum. The one task I dislike about teardrop building is trimming the stuff with a router. Yes, what a mess.
On your hinge holes, after stalking your build journal, I'm confident you'll triumph over this challenge. I think you used contact cement to glue it down, right? I believe I'd heat-gun the edge of the aluminum so I could peel it back and at least see where they are. I'll be curious to sit on my couch and watch how you fix this issue.
T
