Ok – now for the installation of the outside side seals. Since there is not an offset, the seals are necessary to keep dust and rain out when towing. After a long search for a suitable seal – the answer was right under my garage door – the seal that is. I found that the seal that seals the bottom of a garage door is perfect for the top hinge and side seals. It has UV protection, remains pliable , and meant for constant use.
See how the seal bends around the curve and provides an excellent seal no matter what the angle of the hatch may be. (note – the top hinge and gasket will cover over the majority of the top seal. It has not been installed (yet) for clarity)
Just a picture of the top with its first coat of red paint.
Front panel
Here is the hatch in the closed position and latched down. The bolt is in the t-nut for added security while travelling.
